10-09-2020, 05:31 PM
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
Replacing the fresh water pump
I'm looking into replacing the fresh water pump in my coach.
The old one is marked with 2088-422-444, I'm not finding that number available from Shurflo.
The closes that I'm finding is marked as 2088-554-144.
Anyone here recognize this model, will it be a good fit for the coach.
Thanks Richard.
10-09-2020, 06:56 PM
2000 19' Bambi
mt. Prospect
When the 19 year old pump failed last year, I couldn't find an exact replacement. Bought a Shurflo 2088-554-144, rated for slightly higher PSI and GPM, but lots more noise was not in the specs. Moved it a bit, installing a thick rubber pad underneath and flexible hoses between the pump and water lines. That quieted it down to about the level of the original.
No WD, but a great DW!
10-09-2020, 07:03 PM
2017 22' Sport
NCR
, Ontario
Get a shuffle plus the matching accumulator
10-09-2020, 07:37 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Thanks Richard.
Hey Richard, that model will work, like most of them will. Its just a matter of GPM and you want at least 3 GPM. I just replaced the pump in my 94 trailer and like the way it performs. Its a new shurflo Model
https://smile.amazon.com/PowerMaxs-S...2293384&sr=8-9
or if you want to fancy up things go with the Seaflo 55 series running at 5.5 gpm.
https://www.campingworld.com/seaflo-...B&gclsrc=aw.ds
AIR #13
10-09-2020, 10:13 PM
Churubusco
, Indiana
Burned through two shurflows before switching to seaflow, no problem since
1983 Airstream 310 Class A Motorhome
-Rob
10-10-2020, 11:51 AM
Ebro
, Fla Panhandle
Thanks for the tips guys. I'll be going forward with this soon.
Cheers Richard
10-22-2020, 10:26 AM
Ebro
, Fla Panhandle
I put in a Shurflo 4008 RV revolution.
It went in well, but is sending a pulsing signal to the water supply.
It's running well, and quietly.
But I'm feeling the pulsing of the water in the shower head. Plus when turned down in volume down the temp is fluctuation with each pulse.
Will it need an accumulator to smooth things out?
Any other suggestions?
Cheers Richard
10-22-2020, 11:00 AM
Churubusco
, Indiana
If you don't have an accumulator, yea, put one in
Guessing it's getting cold when the pump kicks on because there is a lot less resistance directly to the head compared with a lot of resistance pushing water through the water heater. Accumulator should be easy to install and smooths things out
-Rob
03-11-2022, 02:44 PM
2022 22' Bambi
Hoffman Estates
, Alabama
fresh water pump
Originally Posted by PeterH-350LE
I am also replacing my old shurflo dated 2001. I ordered the fancy 55 from Seaflo and it says in the directions it must have a 25.5AMP fuse, the website says its max draw is 17AMP. My old '78 tradewind only has 20amp fuses so just to be safe I am returning it for the Seaflo 42 series.
03-11-2022, 02:48 PM
2022 22' Bambi
Hoffman Estates
, Alabama
Thanks Richard.
Hello My name is Kevin Nash, I am new here. I found your post from 2020 about the water pump. I am working on my same thing now and wanted to know what you ended up installing in your rig and are you happy with it?
