Old 12-01-2017, 09:07 AM   #21
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Even *if* the filter might be good for 1.6 seasons, it's a cheap item to replace. Doing it as part of the "out of storage" process in the spring pretty much guarantees it will get swapped out.
If you hit the wrong water supply at the wrong time, your filter is good for about one load of dishes. There is always some level of sediment that will plug a filter quickly.
Old 12-07-2017, 02:55 PM   #22
2016 25' Flying Cloud
Nanoose Bay , British Columbia
Replace Pentek with Camco
On Vancouver Island I cant find a Pentek in-line filter except online and then they’re expensive and I’d have to buy a case of 15. I went to my local mechanical contractor supplier (Andrew Sheret Ltd) and for $5 they sold me brass fittings that will allow me to use cheaper and available Camco filters (the Camco filters also have KDF which is said to reduce bacterria growth in the filter when not in use). The Camco filter fits perfectly (same length). The fittings converts the Camco “garden hose thread” to the thread used in the Airstream’s female fittings under sink.
By the way, those plastic fittings Airstream used in the ends of the Pentek filters do easily screw out. Mine did.
gnijman is offline   Reply With Quote
Inline water filter, why not a whole house canister? Vitaver Plumbing - Systems & Fixtures 24 08-04-2019 10:50 AM
Inline filter under kitchen sink SeaLevel Plumbing - Systems & Fixtures 11 09-24-2016 07:34 PM
Best inline water filter. schoochie11 Water Heaters, Filters & Pumps 1 12-06-2015 12:51 PM
345 inline fuel filter info. 345bill Classic Motorhomes 2 09-18-2009 08:44 PM
