Old 02-08-2025, 06:25 PM   #1
JimskyD's Avatar
2018 30' Classic
Bothell , Washington
Remove Alde Flow from 2018 Classic?
The Alde Flow unit in our 2018 Classic 30 started leaking 4 years ago. We had it replaced. Now the new one is leaking too!
Online information seems to indicate that the Flow unit is prone to springing leaks.
It turns out we don't use that much hot water. Anybode have thoughts or experience in just removing the flow unit altogether? It seems like a problemmatic system of questionable utility in our case.
Jim and Sharon Doub
2018 Classic 30
K6TKU
Bothell, WA
WBCCI 03495
JimskyD is offline   Reply With Quote
Old 02-18-2025, 08:11 PM   #2
2021 30' Flying Cloud
Sioux Falls , South Dakota
Jim, no one answered you, so I'll toss a few thoughts out there. Someone who knows much more than I do will probably chime in and correct me.
First of all, the Alde system is not only a hot water heater but also a replacement for the furnace. The idea is a good one, and hydronic heating systems are common on higher-end motorhomes. I wondered why no one put one in a towable RV. Then I ran into the Airstream Alde system.
As you know, the heat source heats a glycol mixture which is used to heat the water. I believe that the Alde unit occupies the space where the hot water heater would go. Since we both have 30' trailers, I'm guessing that your Alde system is under the dinette seat that faces forward, next to the potty room. If you wanted to install a traditional hot water system, where would you put it? Under the stove, where the furnace is on our trailer?
We were looking at Classics, too, until this Flying Cloud popped up. I didn't want all of the "extra" stuff (power awning, Alde system, electronic switches, etc.) I still got stuck with a tankless hot water heater, but I've found ways to work around it, at least for now.
David Lininger, kb0zke
7490
2021 Flying Cloud 30 RBQ
kb0zke is offline   Reply With Quote
Alde flow tank-help needed Vicki J General Repair Forum 5 10-26-2021 10:16 AM
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 64 08-15-2021 06:36 AM
Alde Flow Froglips 2016 - Current Classic (all lengths) 4 06-19-2019 06:09 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
