10-22-2021, 04:07 PM
2016 27' Flying Cloud
Edmond
, Oklahoma
Recurring drain plug failure
Every time we go out in our AS, we seem to experience failure in the drain plug on our water heater. AS dealer said they couldn’t find anything wrong with our water heater but we are frustrated that the problem continues to recur. It’s a pain to keep replacing these plugs only to have them fail on the next trip. Doesn’t seem to matter if we are heating with electric or propane. Anyone else have a similar issue or possible solution?
10-22-2021, 04:20 PM
2020 19' Caravel
Ammon
, Idaho
I am curious, how much torque are you applying while installing it? Could be it is too much.
Is the mode is failure the same each time?
10-22-2021, 04:32 PM
Edmond
, Oklahoma
Yes, the thing is hard to get to but we’ve tried tape, no tape, tight, loose (but snug). Nothing seems to hold up for more than a day or two. Using the camco plastic plugs.
10-22-2021, 04:57 PM
2024 19' Caravel
Washougal
Originally Posted by Lisarhr
... camco plastic plugs.
Try one from Airstream, let us know how that works. Maybe the thread pitch on the Camcos is a bit off.
10-22-2021, 05:16 PM
2018 23' Flying Cloud
Peru
Plug This!
Buy a bag of plastic plugs and/or metal plug. Keep on hand. Use anti-sieze compound on the threads of the plastic plugs or pipe thread compound on the metal plugs. Hand tighten them then use socket 1/4 turn. Check for leaks.These were found at Amazon.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
10-22-2021, 05:51 PM
1995 25' Excella
xxxxx
, xxxxxx
I use the Camco plugs. I put white thread sealant on them, then put them in finger tight, plus about half a turn. I fill the tank and check for leaks. If I get a drip, I snug a 1/4 of a turn at a time until it stops. I doubt if I have ever turned one a full turn before it sealed. I usually put a new plug in at the start of the season and leave it all season.
10-22-2021, 06:05 PM
1994 25' Excella
Waukesha
, Wisconsin
When I bought my 1994 Excella last spring there was a replacement drain plug in the junk drawer left by the original owner. It was an Atwood branded plug, and I immediately noticed that there is a difference between the actual Atwood plug and the ones being sold today.
The Atwood plug had a longer threaded area and a more noticeable taper to the threaded area. No doubt that the current ones don't seal as well. I've had a few bottom out before they got even remotely tight. I tried to find some like the Atwood plug, but no luck so far.
Richard
11018
10-22-2021, 06:55 PM
2014 19' International
2014 Interstate Ext. Coach
Cedar Rapids
, Iowa
No to metal plugs and tape. They are a safety feature designed to blow out if pressure builds in the water heater. Use plastic only.
You might explain “fail” better. Has anyone checked your water heater for proper performance? If they are leaking, you might have a pressure problem and something might not be operating correctly. Just a thought. I’d have it checked out by a professional.
10-22-2021, 07:10 PM
2004 28' Classic
Monument
We have used the same brass plug with Teflon tape for many years. It has never failed. We snug the plug up to finger tight, and then another 1/4 quarter turn. Over tightening, i guess, may result in premature failure. Never had a problem.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
10-22-2021, 07:12 PM
diesel maniac
Airstream - Other
Tucson
, AZ
I don't think that is correct, that's the job of the TPR valve. Someone may have told you that but it wasn't correct. If it were true why bother to install a TPR? My thoughts on the plastic plugs, they are used because people can't possibly strip out the aluminum threads with plastic like they could if they over tightened a brass one. The manufacturer knows DIY people will be removing and installing those plugs and some DIY people feel the need to over tighten everything and aluminum threads will fail easily. Plus the plastic ones are cheaper for the manufacturer.
Brian
10-23-2021, 07:55 AM
Edmond
, Oklahoma
Yes,I had the AS dealer looked at it and they couldn’t find anything wrong with the heater. I’m guessing that we’re tightening the plugs too much. Will try a softer touch and a large package of plugs. I did find Atwood plugs on Amazon.
10-23-2021, 09:32 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
The plugs are a tapered pipe thread. Tighten then too much and you will deform them. Just tighten then to firm, then a tad more.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
10-23-2021, 09:34 AM
2013 27' FB International
El Dorado Hills
Those plugs hardly need to be tightened at all. I wrap the plugs with teflon plumbing tape a couple times then twist on with my fingers. Use a crescent wrench a quarter or half turn after that. All you want is the minimum tightness to stay watertight.
Washington
, Missouri
Similar topic
https://www.airforums.com/forums/f44...ug-228734.html
Inc discussion re relief valve.
Imo, they use plastic since with the tough access, it would be easy to X thread with a brass plug.
i use a deep socket with a 6" extension by hand so i can accurately control the approach then the ratchet the last few threads. Also I use the tube of teflon sealant with camco plastic. My spare is gathering a lot of dust in the spare parts box.
WashMoBob
10-23-2021, 09:44 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Like it or not, you *can* damage the threads on something like this. My guess is that a 2016 trailer hasn't been failing every two days since 2016. Something happened and now there's a problem. With a location like this, getting eyeballs on the threads is near impossible without pulling the water heater ( yuck ) or getting an inspection 'scope. (which is still a bit iffy .....).
2017 23' Flying Cloud
Mesquite
, Nevada
You mentioned getting Atwood plugs from Amazon it’s possible you got an inferior copy from a 3rd party seller.
10-23-2021, 10:33 AM
2013 30' Classic
Key West
zoz
I’m sure Teflon pipe thread is better, but if anti seize is used, make sure it is rated as Food Grade.
10-23-2021, 11:22 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
[QUOTE=DonRich7878;2549420]I’m sure Teflon pipe thread is better, but if anti seize is used, make sure it is rated as
*Food Grade*
Who drinks hot water.
"You don't know where you've been until you leave, enjoy life" RLC
10-23-2021, 11:36 AM
2013 31' Classic
billings
, Montana
…I use permeates thread sealer…..a liquid white small plastic container..with brush…even works on model A head bolts…non hardening
10-23-2021, 11:41 AM
1988 32' Excella
Robbinsville
, New Jersey
[QUOTE=ROBERT CROSS;2549434]
*Food Grade*
Some people use hot water for cooking, also the cold water often comes out of the same faucet as the hot water.
