Old 09-24-2020, 10:47 AM   #1
2018 27' Flying Cloud
Pump upgrades?
On our Colorado vacation, we had our pump go out. The only RV dealer in town happened to have a replacement Shurflow. But looking around it got me to wondering if any of the other brands were really any better. Anybody have thoughts on this? Apparently regardless of RV brand, this is one of the more common issues, and in fact the dealer mentioned the sold 10 last week alone! If the Shurflow units fail this often, there must be units that would be considered an upgrade.
wbrisett is offline   Reply With Quote
Old 09-25-2020, 09:15 AM   #2
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Get a shurflow revolution, strainer and accumulator tank. This should last a long time if you don't run it dry (turn off the pump switch when unattended or not being used). Brad
SuperTrouper is offline   Reply With Quote
Old 09-25-2020, 10:43 AM   #3
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
In our experience Shurflow failure is rather rare. We **live** off our internal tank and pump, camping 6 mos. of the year. Our 2011 is still running fine, knock on wood, and our 1999 never failed either. Something's Up??
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 09-25-2020, 04:04 PM   #4
2018 25' International
Slidell , Louisiana
I agree, Shurflow is a good pump and has an excellent price point. they don't fail often and if they do, it is more likely for cause like air, trash, excessive cycling, etc.
Brian
Old 09-26-2020, 06:52 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The original Shurflow pump on 'Cloudsplitter' was the first item to fail,(on our first outing, bad internal wiring).
AS sent us a new one, no dealer in NY back then.
After 16 years it got very noisy on our cross-country last Season, replaced mid-trip.
The new Shurflow is much quieter and flows more, hope it lasts as long.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 09-26-2020, 04:36 PM   #6
it was the internal valve that failed, so my fresh water tank filled from the city water hookup. Apparently this is one of the leading causes of failures on these pumps according to both our Airstream dealer who I called from the road, and the local RV dealership who sold me a replacement pump (apparently thereís a rebuild kit for these, but they didnít have any). We rarely use the pump and in fact we didnít even have any water in the freshwater tank on this trip when I noticed that it was overflowing.
There are several other pump brands out there, I was just curious if any of them were any better, seems nearly all RVs are using the Shurflows, but I was shocked when the parts guy said he had sold 10 that week alone. I apparently got the last one until their delivery truck came in later that day. (At least I was having some luck).
The fact that itís only 3 years old and rarely used surprised me. But thatís usually when thing fail, they rarely get used.
Old 09-26-2020, 04:53 PM   #7
2008 19' Safari SE
Cary , North Carolina
My trailerís fresh water tank filled in the same manner as you described. Nothing inside the pump or associated with the pump had failed. There was a small piece of trash trapped by the diaphragm that allowed this to happen. Cleaning it out fixed the problem.
Always and always use a water filter. No matter what youíre hooked up to or what youíre filling. Always use a water filter.
2008AS is offline   Reply With Quote
Old 09-26-2020, 05:25 PM   #8
Slidell , Louisiana
totally agree. The pump was likely fine, just a bit of trash in the valve. Ah well live and learn.
Brian
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
