05-04-2021, 04:19 PM
2019 27' Flying Cloud
Dixon
, Missouri
Pump fails to prime
Dewinrterizing my 2018 FC. Full fresh water tank but cannot fully prime the pump....some water - mostly air. Figured I damaged the pump when I winterized with air pressure. Replaced pump but I have the same problem.
The system seems to be sucking air, but from where. Worked well before winterizing. Ideas please!!
05-04-2021, 04:22 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
Did you close the winterizing valve and open summer? The valve handle needs to be parallel with water line from tank to pump.
- Stewart
05-04-2021, 05:01 PM
1994 34' Excella
Warren
, Manitoba
Also check all the fittings and filter between the tank and the inlet side of the pump. Often the gasket on the filter is the problem. Tighten and retighten all the connections, and as s1000pre said, make sure the valve on the winterizing fittings are in line with the suction hose. When you are trying to get water make sure that there is a faucet in the sink open. Yoou cannot suck water from the tank if there are no faucets open.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
05-04-2021, 05:38 PM
Alamo Heights
I'm having the same problem. I think I have a cracked or loose fitting between the fresh tank and the screen in the inlet line... I can pump water out of a bucket and build pressure, but it won't prime from the fresh tank. I haven't worked up to accessing the lines deep under the cabinetry yet... it looks like it heads down to the tank under the fridge in my 26U.
— David
05-04-2021, 07:00 PM
2016 27' Flying Cloud
Hartsburg
, Missouri
Carefully check the twist fittings on the filter and pump to make sure there is a conical washer in each-- they can fall out when winterizing and go unnoticed till you see the kinds of problems you are having now. This happened to me last year-- Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
05-04-2021, 09:03 PM
1995 25' Excella
xxxxx
, xxxxxx
I assume Airstream is still using a strainer before the pump. If so and it is the one with a clear twist off cap, remove the cap and make sure the o-ring that seals the cap is in place and not damaged.
05-05-2021, 11:10 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If the filter bowl is cracked from freezing it will let the pump suck air. Just replace the filter if that is the case.
guskmg
05-06-2021, 02:39 AM
Sag Harbor
, New York
Adding to all the good advice so far . . .
If you can hook up to city water ahead of time, let it run freely from all hot and cold faucets etc., until there is no air left in the system, at all, including the water heater, outdoor shower, sink spray wands, and toilet.
Be sure to open all faucets etc. as the pump tries to get its prime. You don't want any air "resistance" in any lines "pushing back" against the pump.
Good luck,
05-06-2021, 09:39 AM
Dixon
, Missouri
Think I have done everything correctly. But, not sure what valve you are referring to. What specifically is the "winterizing valve"
05-06-2021, 09:58 AM
1994 34' Excella
Warren
, Manitoba
The "winterizing" valve is a valve in line before the pump. It "usually" has a piece of clear plastic 1/4" hose that you put in an RV antifreez jug and pump the solution through your lines. It is a quarter turn valve. When pointed in line with the pump to tank suction line it is closed . If it is pointed down towards the main water line, the valve is open and will suck air. Do you have a manual that came with the trailer?
ACI #7394
1994 Excella 34'
Hensley Hitch
05-09-2021, 09:12 AM
Sag Harbor
, New York
Good advice already . . . after many years of getting ready for summer, without a hiccup, this morning our pump seemed to be sucking air too . . . so . . . double-checked . . .
Bingo x2 -- when replacing the clear filter/strainer cap last fall, guess the O-ring slipped out of place, and I did not notice it . . . probably a "haste makes waste" operator error . . . all good now.
PS -- How about you rockeddy?
05-09-2021, 02:36 PM
2016 27' International
North Augusta
, South Carolina
Pump fails to prime
I couldn’t get my pump to pressurize after pulling the trailer out of storage, either. After checking all the connections for o-rings and proper seals, I was convinced it was the pump. I took off the little screw-on cap of the winterizing valve and pored a tiny bit of water in, turned on the pump, repeated that a couple times and it pressurized, and started pulling water from the tank.
05-09-2021, 02:58 PM
2019 30' International
Pennsylvania
, Pennsylvania
I have a '19 International Serenity. There is no winterizing valve in line before the pump on my unit. To draw antifreeze I remove the input line from the pump and connect the clear tube directly to the pump, other end of the tube goes straight in to the gallon jug of antifreeze.
There is a gasket in the fitting to the input line of the pump. If it's missing that would be a problem for sure. I've almost lost/dropped it before.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
05-10-2021, 03:25 PM
Dixon
, Missouri
The problem was the strainer
Replaced the strainer (from Amazon) and that fixed it. My guess is that I somehow damaged the strainer with too much air pressure as I was winterizing last fall.
I have installed the valve for adding antifreeze to the system. Guess I will be using the pink stuff next fall.
Anyhow, THANK YOU ALL for your advice. It certainly was helpful.
05-10-2021, 03:41 PM
Pennsylvania
, Pennsylvania
Excellent! Thanks for coming back in here and giving us the update
05-10-2021, 04:21 PM
1994 34' Excella
Warren
, Manitoba
Thank you for letting us know the outcome and positive end to the problem. This always makes it worthwhile to give help and advice. Happy 'streaming!!
ACI #7394
1994 Excella 34'
Hensley Hitch
05-10-2021, 06:49 PM
Sag Harbor
, New York
Thanks rockeddy.
05-10-2021, 08:00 PM
2019 27' Globetrotter
McHenry
Try a small regulator for your compressor.
Rockeddy, glad you figured out the problem and got it working again. I had a similar issue last year and like another poster, dropped the o-ring seal when checking the strainer.
Don’t give up on blowing out the lines - just use a small regulator. I found this one on Amazon and use it with my Viair compressor. More affordable than Viair’s.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
05-16-2021, 11:30 AM
2018 25' International
2018 33' Classic
Ashburn
, VA
Good luck,
That's exactly what happened to me when I was winterizing. Make sure you have an open faucet.
05-17-2021, 09:29 PM
2016 28' International
Nicholasville
, Kentucky
Loss of prime
Same thing happened to me this spring after blowing out the lines with air last fall. I connected a hose to the upstream side of the pump and poured water into it, legit suck a gallon jug dry, then hooked it back to the line from the freshwater tank and it primed from the tank. Think it has to do with blowing all the water out of the impeller housing. Hope that helps.
Dan
