Old 05-22-2025, 01:11 PM   #1
Birmingham , Michigan
Pulsating Lights
I have a 23 Pottery Barn. When I attempt to use my bathroom faucet via my water pump, the water and bathroom lights pulsate along with the sound of the pump pulsating. Any idea what causes this?
Aquabud1972 is offline   Reply With Quote
Old 05-23-2025, 09:40 AM   #2
2025 25' Trade Wind
Beaver Dam , Wisconsin
My 2025 Trade Wind cold water pulsates while running, sometimes. The lights flicker when the pump first starts, but does not continue to pulsate.
The hot water does not do that.
I am not sure it is a problem. Is it a problem for you?
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
PaulBristol is offline   Reply With Quote
Old 05-23-2025, 02:56 PM   #3
2022 33' Classic
Chesapeake , Virginia
I remember noticing the lights flickering while running the pump (and flushing the macerator toilet) when our WFCO converter later died in the early morning hours. I was not experienced enough back then to have looked at the SOC% on the CZone. I think I had a low battery bank at the time, and the converter was slowly failing.
OP could always install a IRVWPC, that would smooth out the pump.
I do not notice this now, and have not since upgrading the electrical system. Of course that also included upgrading 12V buss wiring.
BGClassic is offline   Reply With Quote
Old 05-23-2025, 03:13 PM   #4
"Cloudsplitter"
Think of it as sharing the power syndrome.
Ours is also quieter when running through the converter.
Old 05-23-2025, 09:25 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
When the pump works against the pressure in the line for part of each revolution it draws more current and that drops the voltage. The incandescent bulbs in the older trailers do not respond as quickly to changing voltage as the newer LEDs. You may be able to stop the flickering if you add a large value electrolytic capacitor to each affected light fixture, try 100 uf or larger at 16 volts or more.
Al, K5TAN and Missy, N4RGO - WBCCI 1322
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Pulsating ceiling lights & fridge - 2012 international RainBeau Electrical - Systems, Generators, Batteries & Solar 1 06-08-2023 05:57 PM
Pulsating ceiling lights & fridge - 2012 international RainBeau Electrical - Systems, Generators, Batteries & Solar 0 06-05-2023 08:10 PM
Shurflo pump recycling, pulsating help exallen General Repair Forum 5 04-08-2014 12:29 PM
all 12v lights pulsating??? LI Pets Electrical - Systems, Generators, Batteries & Solar 4 07-10-2013 10:21 AM
Pulsating water pressure,2008 Safari kingfisher Fresh Water Systems 9 02-16-2010 01:27 PM
