Old 01-18-2025, 12:48 PM   #1
2023 27' Flying Cloud
Greensboro , Arizona
Pinhole leak in tankless water heater
We discovered a pinhole leak in the intake tube during setup. Our FC is less than 2 years old and under warranty. Should I patch the leak with an epoxy stick and resin tape or live with the leak until I can take it in for service? If I patch it, will it void my warranty?
Jmwatson7 is offline   Reply With Quote
Old 01-18-2025, 02:13 PM   #2
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
I've fixed all sorts of things and never had any questions on warranty issues. So, I wouldn't worry about it especially if you're confident in the repair. However, as you're probably aware having a leak and water not where it should be isn't good and the leak could get bigger. Also, the system might not fully pressurize and the pump will keep running.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Trading tanked hot water heater for tankless hot water heater? robwolff3 Water Heaters, Filters & Pumps 16 11-11-2021 08:10 AM
Tankless Water heater Leak - 2021 Bambi 16RB FunBoss20 Water Heaters, Filters & Pumps 1 04-07-2021 09:44 AM
T1N Interstate fresh water pinhole leak InterBlog Sprinter and B-van Forum 9 01-27-2019 03:13 PM
Pinhole leak in Atwood Water Heater louaxtjr Water Heaters, Filters & Pumps 21 02-07-2016 06:19 PM
Pinhole propane leak to oven tarh2o Stoves, Ovens & Microwaves 8 01-04-2014 08:37 PM
