Old 05-01-2021, 07:12 PM   #1
2019 25' Flying Cloud
Maple Ridge , British Columbia
Only getting warm water
any ideas? i am new to this
2019 FC RB
water has low pressure and only luke warm at best.
outside pressure from hose is good.
at the end of my rope with airstream..
MrScratch is offline   Reply With Quote
Old 05-01-2021, 07:19 PM   #2
2019 30' International
Pennsylvania , Pennsylvania
There are numerous recent posts, in the past few weeks, relative to your issue.
First thing I'd check is the outside shower faucets, make sure they are turned off.
Next is possible air in the lines. This situation can arise during the de-winterizing process.
Maybe more probable is a clogged screen on the mixing valve.
Use the search bar up top of the page and check it all out!
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-01-2021, 08:29 PM   #3
ok thank you.
Old 05-01-2021, 09:00 PM   #4
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
First... Do you have good pressure when running from your fresh tank using the pump? If so, you may need to replace your city water shurflo inlet. It has a built in pressure regulator, I just replaced mine on my 2021. If your pressure is still poor off of the pump: Open all of the faucets starting with the one furthest away from the city water feed. Let them run for a few minutes and close. Let us know how that works?
s1000pre is offline   Reply With Quote
Old 05-02-2021, 07:56 AM   #5
2017 28' International
Jim Falls , Wisconsin
If the above doesn’ t work, then clean your mixing valve. Take it off, clean the screen, and soak the valve for 2 hours in white vinegar. This has worked for me in the past.
Daquenzer is offline   Reply With Quote
Old 05-02-2021, 08:23 AM   #6
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
+1
This did the trick for me.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 05-02-2021, 12:14 PM   #7
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Put the hot water heater bypass valve into the closed position.
NOAZRK2690 is offline   Reply With Quote
Old 05-02-2021, 12:45 PM   #8
2019 25' International
Washington , Washington, D.C.
Where is the mixing valve located. Pray it is not difficult to remove.
PatLee is offline   Reply With Quote
Old 05-02-2021, 03:32 PM   #9
2019 22' Sport
Waynesville , Missouri
Hot water bypass valve
Had the same issue, low pressure, only warm water and air seemed to be mixing in.. I turned the hot water bypass 90 degrees and bingo! Full, nearly boiling hot water running at high pressure. I think the bypass valve allows cold water to mix with hot. On my 2019 Sport, under the bed, I have access to the plumbing to the heater. There’s a valve about half way up the side of the heater. That’s the one I turned to stop the cold water mix from occurring. It was very dramatic!
DAVSCH is offline   Reply With Quote
Old 05-03-2021, 11:49 AM   #10
Hi every one
thank you
I see a yellow ball valve thst is in line with the pipe.
the mixing valve, i imagine its a pain and messy to take out?
There is good pressure with only the pump going
the kitchen being the furthest, seems to oscillate when running off street side water.
temp from pump only is pretty hot.
street side is luke warm..
Old 05-03-2021, 12:44 PM   #11
2019 27' Globetrotter
Missouri Valley , Iowa
About 2 weeks ago I cleaned my mixing valve. It was partially clogged with debris like you sometimes see in the aerator of a sink faucet. My heater is under the bathroom sink and is easy to get to. Wulfraat has a good pic of the valve in post # 18 of a 4-24-21 thread. It's titled "Atwood 6 gallon water heater mixing valve." Other posts describe removal and cleaning. It's not difficult if the heater is accessible.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-03-2021, 03:36 PM   #12
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
2019 FC RB
Hi MrScratch,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 05-03-2021, 09:00 PM   #13
how do i take it off? imagine im draining the hot water tank and all that?
Old 05-03-2021, 09:47 PM   #14
Yes, drain the water heater. Disconnect the red (hot) PEX line and the white vinyl reinforced hose from the valve. I used big Channel lock pliers to carefully turn the valve until it's loose and then you can likely remove the rest of the way by hand. The brass fitting that threads into the heater was the one that had the debris in it. That fitting can be removed from the mixing valve and then you should see the clogging problem. I didn't soak in vinegar - but it's probably a good idea to do so as well as remove the debris. I don't know what is under the black plastic covered end - so maybe keep it out of the vinegar. Reassemble in reverse order using teflon tape on the brass fitting going into the heater. Refill heater and check for leaks. The REASON for my removal of this valve was a noticeable difference in flow at the sinks when switching back and forth form hot to cold or cold to hot. Always more flow from the cold.
Dan
Old 05-04-2021, 06:43 AM   #15
thank you Dan.
i will have a look at this.
Old 05-04-2021, 06:59 AM   #16
Dennis C's Avatar
I couldn’t budge mine with channel lock pliers. I had to buy a 10” pipe wrench to get it off.
I called Airstream technical support when I had this issue earlier this year at a campground. They recommended soaking the valve in vinegar or CLR for a while to remove deposits. I used CLR, which is also used to clean coffee makers. It bubbled up quite a bit as the deposits dissolved. I used a Q-Tip to help clean the screen. I thoroughly rinsed it when I was finished cleaning it, and then reinstalled it. Now everything works perfectly. For my trailer, a 15/16” socket was required to remove the water heater drain plug. Overall, this was an easy repair. The hardest part is accessing the mixing valve.
Good luck!
Dennis
Old 05-05-2021, 05:51 AM   #17
Anyone - where is the mixing valve in a 2019 25' Front Bedroom Twin? And how do you remove it? Thank you!
Old 05-05-2021, 07:48 AM   #18
thank you. I guess i am playing plumber !!
just happens to be one next to me at my campground
so this wont " void my warranty" etc?
Old 05-09-2021, 10:23 AM   #19
tommym1's Avatar
2017 27' Flying Cloud
Lansdale , Pennsylvania
2019 FC RB
This happened to us last year. Remove the mixing valve and replace. Soak the original in vinegar and keep as a spare.
tommym1 is offline   Reply With Quote
Old 05-10-2021, 07:58 AM   #20
[QUOTE=tommym1;2492080]This happened to us last year. Remove the mixing valve and replace. Soak the original in vinegar and keep as a spare.[/QUOTE
ok. so when i have the pump running at the same time the pressure is good as well.
The water is intermittent. hot , warm. but not consistent. is this familiar to the issue im having?
thanks
Hot water heater just gets water to luke warm highlandsnc Water Heaters, Filters & Pumps 14 04-29-2021 08:58 PM
Only warm water in shower mansfielddi Fresh Water Systems 4 01-01-2016 07:03 PM
Water warm, not hot. curnes Water Heaters, Filters & Pumps 8 10-24-2014 08:17 AM
Bathroom light switch getting very warm Lothlorian Lights - Interior & Exterior 5 07-27-2009 02:54 PM
Its getting warm out....I need A/C Bearmechanic Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-04-2009 08:03 AM
