Old 08-09-2021, 12:07 PM   #1
Menlo Park , California
On demand heater getting to hot despite set temp
Hello there,
I know there were lots of discussions about on-demand/tankless water heaters, etc. Besides the pros and cons, I lately ran into an issue on our '21 Globetrotter, where the water simply got too hot.
We use the warm water in the shower full throttle and had it preset on the on-demand heater switch to like 104F (I believe). This worked fine for month, but lately whenever the shower was switched off (for eg soaping) and then on again the water will simply get crazy hot (more what feels like 112 or 115).
Just wondering if this is a common "problem", ie works as designed or should it "steadily" hold the oreset temp of like 104F and something might be wrong with our unit?
Cheers,
Chris
chrispe is offline   Reply With Quote
Old 08-30-2021, 10:58 AM   #2
No-one ever seen a similar issue?
Old 08-30-2021, 11:03 AM   #3
2021 22' Caravel
Bozeman , Montana
Mine is fine. I have it set to the hottest temp and it's as hot as I want it to me. Sorry that you're having problems.
Brian R. is offline   Reply With Quote
Old 08-31-2021, 09:28 AM   #4
Thanks Brian!
Just wondering, because if that's the case then need to go to the dealer I guess, which I tried to avoid...
Northeast Doing something wrong despite 6V AGMs AirstreamCSH Boondocking 1 09-23-2018 07:32 AM
adjusting water temperature with on-demand Precision Temp nickclifford Water Heaters, Filters & Pumps 4 05-29-2018 10:13 AM
strange thing, Precision Temp on-demand water heater nickclifford Water Heaters, Filters & Pumps 2 10-04-2016 08:40 AM
2010 interstate LPG won't fill despite being empty ragtopjl Airstream Motorhome Forums 4 05-29-2014 11:57 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
