Old 09-17-2020, 01:17 PM   #1
1993 34' Excella
Barry's Bay , ON
Ok to upgrade pump pressure?
Itís time to replace our water pump. We have a 35psi unit installed but RV dealers around Kelowna, BC seem to only carry 55psi units.
Has anyone done this upgrade without issue?
Iím hesitant to test the plumbing in our 1993 Excella with the extra pressure, although nearly all the pipes have been replaced with pex now anyway.
LiamG is offline   Reply With Quote
Old 09-17-2020, 01:18 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
It is fine
Old 09-17-2020, 01:51 PM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Are you a bit handy?
Do an air pressure test. Rig regulated compressed air to city only connection. Close all faucets and test away
I made a combo winterizing / pressure test fitting for my rig.
Air fitting, ball valve, pipe T fitting, pressure gage, water hose connection.
Install assy, pressurize to regulated value, close valve, monitor pressure gage.
Air leaks are easy to cleanup from and youíve got a jam up blow out fitting. This is real close to how new home construction rough plumbing is tested.
Got a feeling youíre ok but Iím a long way from hands on inspection.
Blame hurricane Sally.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-17-2020, 01:57 PM   #4
1993 34' Excella
Barry's Bay , ON
Iím a bit handy but weíre on the road and I donít have access to the tools required for a pressure test.
Would the purpose be to see if pressure is escaping somewhere, as a result of there being too much pressure from the pump?
Old 09-17-2020, 02:10 PM   #5
GCinSC2's Avatar
No the purpose would be to test existing plumbing as your concern was holding higher pressure.
Tools, pipe tape, couple of large channel locks or pipe wrench and open end wrench for gage.
I could send you e-m or text pic of mine if youíd like.
S/OS #001
Old 09-17-2020, 09:12 PM   #6
1993 34' Excella
Barry's Bay , ON
Makes sense, Iíll post the results after I test in case anyone else comes along searching for the same answer down the road.
Old 09-18-2020, 10:41 AM   #7
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
PEX systems are far more capable than 55lbs
bibbs is offline   Reply With Quote
Old 09-18-2020, 10:45 AM   #8
Long Island , New York
Does the OP's 1993 Excella have PEX plumbing in all the lines?
Originally Posted by LiamG View Post
I’m hesitant to test the plumbing in our 1993 Excella with the extra pressure, although nearly all the pipes have been replaced with pex now anyway.
Would not the remaining old copper plumbing be a weak link in the chain? [and presumably buried where access is the most difficult?]
Peter
Old 09-18-2020, 03:40 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Not copper PB tubing.
Old 09-18-2020, 10:29 PM   #10
1993 34' Excella
Barry's Bay , ON
There is still a bit of copper kicking around, and yes itís only in the hard to reach places.
I think the main problem with the pump was a clogged pre-pump filter that I didnít even know existed so I hadnít cleaned it in the two years weíve owned the trailer.
Itís running much more quietly and efficiently now... so Iíll save the new pump for when we really need it.
Old 09-18-2020, 10:44 PM   #11
bibbs's Avatar
1975 26' Argosy 26
Vista , California
If the remaining piping is copper then there is even less chance of failure.
Old 09-19-2020, 12:20 AM   #12
There is still a bit of copper kicking around, and yes it’s only in the hard to reach places.
I think the main problem with the pump was a clogged pre-pump filter that I didn’t even know existed so I hadn’t cleaned it in the two years we’ve owned the trailer.
It’s running much more quietly and efficiently now... so I’ll save the new pump for when we really need it.
Thanks OP for the feedback, that this situation is resolved for now. Good that you found the filter, as it should be part of the winterization process.
Happy trails,
Peter
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
Does on-board water pressure regulator protect against excessive air pressure? Hermes Winterizing, Storage, Carports & Covers 2 10-07-2018 02:25 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
