Old 04-06-2010, 01:00 PM   #1
1978 29' Ambassador
Martinsville , Indiana
obsolete 36800 water pump
I have been told that the Jabsco 36880-1000 is obsolete and the new number is 36950-2000.
1) The source is VERY reliable
2) I wish to know if anyone has observed that replacement AND
3) I see that StarMarineDepot has one for $204.95. Any comments on StarMarineDepot- good or bad.
ambassadorT is offline   Reply With Quote
Old 04-06-2010, 01:19 PM   #2
2006 28' International CCD
Houston , Texas
I had Jabsco on my boat. Replaced it with a Surflo for about $90.00 and get two years out of it. Same with AS. Jabsco not worth the money, IMHO.
28totow is offline   Reply With Quote
Old 04-06-2010, 08:59 PM   #3
1976 25' Caravanner
Campton , New Hampshire
Why not fix it , parts are still available ? Mine is 34 years old and still going.
ticki2 is offline   Reply With Quote
Old 04-07-2010, 06:39 AM   #4
1978 29' Ambassador
I have, however the threaded port hole on the base unit (female)where the pressure regulator meets the base unit(male) squirts water when pressure is applied. The male end is plastic and I am just not sure if the female is stripped so I'm opting for a new one. By the way the regulator is only a year old and i really hate to discard the whole unit but then why not at $204.95. The price on parts is almost half that.
Water Pump Vomits water out of faucets! thoreaulycra Water Heaters, Filters & Pumps 5 12-19-2008 11:12 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
Rebuild PAR 6800J (Jabsco 36800) or Replace with New Pump trevisgardne Water Heaters, Filters & Pumps 3 05-02-2007 09:20 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
