Old 06-14-2024, 12:35 PM   #1
Hurley , New York
No hot water (2021 BC 16x)
Hello all,
New airstreamer here. I recently picked up a 2021 BC 16x and have no hot water. Iíve tried on both LP and electric, to no avail. Iíve also tried hot/boost as well. As a note, water seems to flow fine from both cold and hot knobs, but temperature wise, the water only comes out cold. Would love some thoughts on what to look at, as Iím stumped right now. Thank you!
Jd455g is offline   Reply With Quote
Old 06-14-2024, 08:49 PM   #2
1988 32' Excella
Robbinsville , New Jersey
Check valves for bypassing the water heater for winterizing.
Old 06-15-2024, 08:08 AM   #3
2022 27' Globetrotter
Huntington Beach , California
Is this a Truma? If so, after ensuring you have propane and valve is open, turn off the WH at display, remove the exterior WH cover, switch to off, wait a few seconds, turn back to on at the WH, then back to on at the interior display
Slvr_Lining is offline   Reply With Quote
Spacecamp 16X :: 2021 Airstream Basecamp RobertD Airstream Registry Discussions 0 03-27-2021 07:02 PM
Things to Check on a 2021 Basecamp 16X Driver912 Base Camp 1 12-15-2020 09:08 PM
2021 Basecamp 16x in stock at Airstream OC Oremus Base Camp 0 11-20-2020 09:16 PM
Equalizer Weight Distribution Hitch Questions for 16X (2021) MSheri Base Camp 23 09-12-2020 11:02 PM
No hot water out of our new BC 16x shower JDub802 Plumbing - Systems & Fixtures 1 09-04-2020 06:52 PM
