Old 04-17-2022, 10:34 AM   #21
1964 17' Bambi II
Nashville , Tennessee
The height of my old water heater is 14". The new one has a height of 12 3/4". I'm wondering if I could just connect the left and right sides using the converter kit and connect the bottom to the existing bottom horizontal edge, and not even connecting the top horizontal edge. It might be able to be secure enough for travel, maybe? What do you think?
Thanks, TnMike
1964 Bambi II restored and customized few years ago.
TnMike is offline   Reply With Quote
Old 04-17-2022, 12:05 PM   #22
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Thanks, TnMike
It's not the overall height that you're worried about, it's the cutout height. The flange on the outer edge of the water heater will overlap the sides of the cutout.
Which water heater are you trying to replace? If it's the Atwood G6A-6E the cutout dimension I'm finding for it online is only 12-5/8", which means that you actually might have to enlarge the opening 1/8".
Be sure you're measuring the cutout opening and not the flange which overlaps it.
Richard
11018
richard5933 is offline   Reply With Quote
2015 Eddie Bauer - Need to replace hot water heater AnnaLoveG Water Heaters, Filters & Pumps 8 06-09-2021 05:59 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Need to replace water heater in '77 argosy 28' pdfr67 Water Heaters, Filters & Pumps 1 05-14-2007 04:24 PM
Need to replace water heater... Hotlead Water Heaters, Filters & Pumps 10 05-29-2005 12:04 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
