Old 04-12-2021, 07:31 AM   #1
2019 27' Globetrotter
Missouri Valley , Iowa
Mixing valve hose
I removed the mixing valve to clean debris from its screen on my water heater. 2019 Globetrotter, 27'. Water heater: GE 9 EXT WIPL. When I reassembled, the 9" hose (that apparently provides cool water to mix) has a tiny seep from the mixing valve end of it. It has a rubber gasket that compresses on the 1/2" brass fitting of the mixing valve. And it's tight. Any suggestions on stopping the leak ??
Dan
Farmer Dan is online now   Reply With Quote
Old 04-12-2021, 10:07 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Dan,
A pic might help of the seal thingy.
Is it conical black rubber sorta?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-12-2021, 10:16 AM   #3
2020 19' Caravel
Ammon , Idaho
If the fitting is tight enough then I would replace the gasket/o-ring/seal.
OutdoorIdaho is offline   Reply With Quote
Old 04-12-2021, 09:08 PM   #4
The seal is a thingy exactly as Gary described !!! And it seems to be molded on / in the connecting nut. I installed the hose and pressurized the system and in about 3 hours a paper towel folded into 4 layers and placed below the fitting wasn't wet clear through. I'm thinking about squeezing some RTV silicone into the nut and installing. Let it set for overnight after installing and then pressurize and check again. Worst case - I have to buy a new one. Thanks for the responses.
Dan
Old 04-13-2021, 04:38 AM   #5
GCinSC2's Avatar
Dan,
Hardware or home center, plumbing it's possibly/likely a seal for PEX fittings. See sample from my PEX survival kit. Not sure if they sell the seal separately but a fitting has it. Showing one in place and one removed. And it just pops off.
Gary
S/OS #001
Old 04-13-2021, 07:11 AM   #6
GCinSC2, I bought brass fittings, barbs and reinforced vinyl 3/8" hose with the intent of making my own hose assembly. The original appears to be about 1/4" hose so I was concerned that the mixing valve may not handle the larger ID hose I bought. But I could get 1/4" barbs to try. And the original assembly is only 9" long.
Dan
Old 04-13-2021, 12:58 PM   #7
Dan
Well ó hereís an unexpected result on my water heater hose. I fired up the heater for 20-25 minutes. Shut it off and had lunch. When I checked next time the joint was dry. The heat had migrated to the leaky fitting and stopped the leak. Now Iíll have to check to be sure the leak doesnít return when things cool down. I hope Iíve attached a pic of the hose !!
Old 04-13-2021, 01:23 PM   #8
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
Has anyone just eliminated the mixing valve?
My 2004 did not have one. My 2018 FC valve needs cleaning frequently and the hot pressure is never that great.
I would cap the cold feed and install an elbow in place of the mixing valve.
sb55 is offline   Reply With Quote
Old 04-13-2021, 02:02 PM   #9
2007 22' International CCD
That could cause a scald hazard. The mixing valve is there to mitigate that possibility. Filtering all the water that goes into the Airstream helps prevent clog issues.
Old 04-13-2021, 02:04 PM   #10
Now, that's an interesting idea !! I suspect the mixing valve is to prevent getting burned with hot water.
Dan
Old 04-13-2021, 03:33 PM   #11
2020 19' Caravel
Ammon , Idaho
In addition to preventing scalding, I have read that the mixing valve serves to increase the effective capacity of the water heater.
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 10:41 AM
2017 Classic Hot Water Mixing Valve Calibration rivetville 2016 - Current Classic (all lengths) 74 08-17-2017 04:20 AM
Shower Mixing Valve Cartridge Replacement jmellana Plumbing - Systems & Fixtures 2 07-29-2017 11:34 AM
Atwood XT Water heater mixing valve orloffgray Plumbing - Systems & Fixtures 0 03-23-2016 07:55 AM
Need mixing valve G. Traveler Sinks, Showers & Toilets 5 11-01-2011 06:15 PM
