Old 03-09-2022, 01:01 PM   #1
Kensington , Maryland
Low H.Water flow & City Water Inlet / Backflow
Please tell me I'm not imagining things. Here is the scene:
1. Replaced the Mixing valve because it was showing all the usual signs of "gunk" in the screen. The screen was 1/2 full of calcium deposits.
2. This did not fix the low H.Water flow issue. Infact, the slow amt. of heated water would turn to cool. This is very typical for a bad mixing valve, with me?
3. Reaching for a 6 pack of beer I noticed fairly loud air/water gurgling sound from the City Water Inlet. That can't be related right?
4. Pulled the City Water Inlet. Hooked a garden hose to it and it would not open to allow flow into the camper...or in this case my garden
5. Disassemble the valve, clean the seals, reassemble and attach the garden hose. Water passes thru the Valve as it should.
5. Reinstall the City Water Inlet valve.
6. The bloody H.Water is working great.
7. Sit cross legged on my front lawn drinking and wondering why, just why?
-J
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 03-09-2022, 01:41 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Josh
Yes several theories.
Correct or acceptable brand of beer.
The answer is 2. Thatís an homage to Tom and Ray The Tappet Bros.
You found the missing ground wire for the mixing valve.
Your humble scribe is sitting by the campfire on a dreary has been damp day and is just a bit bored pre lamb chop dinner.
Iím clueless actually the best theory.
And now back to our regularly scheduled confusion.
Gary
GCinSC2 is offline   Reply With Quote
Old 03-09-2022, 03:43 PM   #3
If it stumps you G. than we are all doomed.
Kudos on the Tappet Bros. reference.
Old 03-09-2022, 03:56 PM   #4
2017 25' International
West Lake Hills , Texas
Was there debris on the city inlet?
Did you have an external pressure regulator attached to city water during any of this?
Fungus is offline   Reply With Quote
Old 03-09-2022, 05:08 PM   #5
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
Anybody have the number for Dewey, Cheatham, and Howe?
JEWare
John Ware is offline   Reply With Quote
Old 03-09-2022, 06:09 PM   #6
GCinSC2's Avatar
Br549
Old 03-09-2022, 06:31 PM   #7
No I did not have any external regulator...straight from the house hose bib.
Was there any debris in the inlet? Maybe. The bugger would not allow water to pass thru prior to me disassembling and cleaning. It did allow a dribble of water, really nothing. After cleaning and reassemble water would pass thru it just fine and the dab-gum water heater flow was back to normal.
Somebody call a nurse.
City water inlet and potable water inlet replacement sizing? LiamO86 Sprinter and B-van Forum 2 05-09-2019 05:05 PM
city inlet & 30 amp location Mx468 Plumbing - Systems & Fixtures 9 01-19-2017 10:01 PM
Backflow preventer bevman Fresh Water Systems 2 03-02-2008 12:53 PM
Water Backflow Check Valve? Lee Davis Fresh Water Systems 4 01-27-2006 05:20 AM
