Old 05-21-2023, 11:35 AM   #1
GTX
2018 Tommy Bahama Interstate
Toronto , Ontario
Interstate 2018 water heater working no hot water.
I am having some strange issues with the water heater:
- The propane is on, checked the stove.
- The electricity is on, checked the water heater.
- Water pump on, there is water going to the heater.
- There is propane.
When I switch the hot water on:
- The water heater exhaust fan starts.
- There is either no propane flowing to the heater or no ignition or something else.
Water flowing, heater exhaust fan on, no hot water
I searched the internet a lot, but not much help, need your help.
Name:	Screenshot 2023-05-21 123301.jpg
ID:	432144   Click image for larger version
Name:	Screenshot 2023-05-21 123357.jpg
Name:	Screenshot 2023-05-21 123414.jpg
ID:	432146   Click image for larger version
Name:	Screenshot 2023-05-21 123429.jpg
GTX is offline   Reply With Quote
Old 05-21-2023, 07:41 PM   #2
GTX
Toronto , Ontario
Narrow it down to this part
It is either blocked or defective, still, very happy with the finding.
Old 05-21-2023, 08:21 PM   #3
2007 22' International CCD
That is probably the pressure switch that detects the proper airflow (suction) from the blower motor. It’s a typical safety switch in most tankless water heaters. When the blower is running the two wires should be shorted by the internal switch.
Verify that the wires to the switch are making good solid connections. Pull both of the connectors off the switch one at a time, the put them back, verify function in the next step.
Quick function check, disconnect the clear tubing. With the heater turned OFF suck gently on the end of the tubing. The switch should close, verified by a multimeter set to ohms across the disconnected switch terminals. The switch should not leak ‘lots’ of air, it should hold the suction., and stay closed.
Failing that, time for a new one.
Trading tanked hot water heater for tankless hot water heater? robwolff3 Water Heaters, Filters & Pumps 16 11-11-2021 09:10 AM
Water heater working but no hot water at faucet DCPAS Plumbing - Systems & Fixtures 4 01-11-2021 10:34 AM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
Hot water heater not working properly kiddoc1 Plumbing - Systems & Fixtures 6 03-27-2014 05:37 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
