10-18-2020, 11:29 AM
2019 27' Globetrotter
Litchfield Park
Intelligent RV Water Pump Controller
The product made by this Canadian company looks interesting:
http://irvwpc.com
Has anyone on the forum ever installed one of these and what were your results? Did it help with water pump noise?
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
10-18-2020, 02:48 PM
2014 27' FB Eddie Bauer
Coldwater
, Ontario
Well this sure looks interesting and the theory is solid - monitor line pressure with a transducer and then modulate pump line voltage to control pump speed and which prevents the pump from rapidly cycling on/off thus eliminating the loud rumbling.
I’ll try one of these when we head out next time. If the border ever opens.
10-18-2020, 03:20 PM
2017 30' International
Broomfield
ah, the easy start of water systems voltage / amperage regulation is a good thing!
I wonder how this works in conjunction with an accumulator tank, which attempts to regulate line pressure itself but way of an air bladder that expands / contracts as water enters / exits the system... I might shoot them a note. Go Canada BTW eh?!
10-18-2020, 05:20 PM
2017 28' International
Jim Falls
, Wisconsin
This is one thing I would definitely get if I boondocked a lot and used mostly the water pump for water. The sound difference is significant based upon their own video. Cost is 219 canadian and 167 U.S. plus any adapters.
10-18-2020, 05:37 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Do I want to fix a problem I don't have??? 🤔
Or stay busy with the ones I do?
Neither😂
10-19-2020, 08:40 AM
2019 19' Flying Cloud
Temecula
Neither😂
Perhaps the best experienced advise I have ever read!
10-19-2020, 11:12 AM
2018 30' Classic
Bothell
Here is a note I just sent to IRVWPC:
We have the Shurflo 4088 on our airstream classic. We use the water pump and supply water from the fresh water tank. In three years the pump has failed twice. The first time I replaced the pump head containing the pressure switch. On the second failure I further investigated. The microswitch contained in the pump-mounted pressure switch had its contact surfaces pitted from the switch-open arc, eventually raising the contact resistance and causing the switch heat up and totally fail. The arc voltage was several thousand volts. I replaced the microswitch (amazon $10 for three) and added a snubber RC (100 ohms and 1ufd) across the contacts. The switch-open voltage is now about 40 volts and no arcing occurs.
Without your system or a snubber, the pressure switch WILL fail and cost the owner somewhere between $200 and $10 (depending on how they fix it)
Jim and Sharon Doub
2018 Classic 30
K6TKU
Bothell, WA
WBCCI 03495
12-29-2020, 08:42 AM
Litchfield Park
We purchased one of these units and I installed it yesterday.
The difference in pump noise is dramatic. Much, much quieter.
So far, we are happy with this. Will let you know how things go down the road.
Steve
Steve Jones
12-29-2020, 02:03 PM
2014 27' FB International
Lewisville
Looking forward to an update, looks like a cool idea.
02-06-2024, 11:36 AM
2017 19' International
Rosemere
, Quebec
Steve
Still satisfied? Still performs well?
02-06-2024, 02:59 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
I installed the IRVWPC about a year ago. It was and still is a great upgrade. No issues whatsoever.
Highly recommend this product!
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
02-06-2024, 04:24 PM
GB
2016 27' International
1997 34' Limited
Saint Cloud
IRVWPC Water Pump Controller
Ditto
Works great and no more annoying water hammer sound.
Gil
"Everyone buys on emotion and justifies with logic.
That is why I own 2 Airstreams... I needed them."
02-06-2024, 05:50 PM
2015 20' Flying Cloud
Kingsport
, Tennessee
There are other more recent threads on it; I installed one several years ago, am glad to have…
-Leslie
WBCCI #1051
02-06-2024, 09:19 PM
2023 25' Flying Cloud
West Olive
, Michigan
I had Truma (Elkhart) install a new AquaGo water heater last spring and I installed the IRVWPC the next day. Amazing results… Hot Water without waste (unlike Gerard I replaced it with)… operates like my old tank water heater in previous trailer… and the IRVWPC smoothed out the water pump and hums along as a proper pump should… and will trickle flow at kitchen faucet.
Notes:
- I added foam pipe wrap where some water pipes were vibrating against the camper.
- I installed the unit under the fridge by my water pump.
02-06-2024, 11:31 PM
2023 23' International
Calgary
, Alberta
Great Tech
I installed one last year and it works great - less noise, and more control. Changes the pump from a stop-start device to variable rate flow.
East to install.
02-07-2024, 05:50 AM
2008 27' International FB
Petaluma
6 month's on ours. Works great!
Looking for adventure in whatever comes our way.
- Brad
02-07-2024, 07:20 AM
Tampa
Airstream YouTuber, "Thirteen Adventures" installs the controller
BTW, he's been doing a lot of water system videos lately.
02-07-2024, 07:37 AM
2019 25' Flying Cloud
Houston
I installed one in May 2023. We have used it extensively. The thing is awesome. Highly recommended.
The only issue I have had is when I de-winterized last weekend, the water pump would not run and a red light was flashing on the IRVWPC. Turned out that in trying to pull water from my long dry system I triggered the dry pump shut off because the pump did not prime within the cutoff time. The solution was to shut off the pump and turn in back on to allow it more priming time.
02-07-2024, 09:50 AM
West Olive
, Michigan
Good to know, thanks!
All things in time, all you'll ever need...
04-06-2024, 05:49 PM
2023 25' Globetrotter
Ancient City
Is there a better WP that just works like it should or is the micro processor unit the wy to go?
