Old 08-08-2024, 04:11 PM   #1
2017 25' International
Moncks Corner , South Carolina
I’m in Hot Water
Greetings fellow, streamers,
Our 2017 international 25FB has a Atwood XT water heater which works fine on electric and on gas IF I manually light it - I did clean the contacts on the electrode/spark probe, which were pretty corroded, and I also checked the gap according to specs with no success. Before I go and buy a replacement spark probe, is there something I might be missing or other testing I should do ? It works fine when manually lit, but not my preferred method.
As always, thank you in advance for any help you can offer
BetterBoat
Betterboat is offline   Reply With Quote
Old 08-08-2024, 04:32 PM   #2
Lafitte's Avatar
2019 25' Flying Cloud
Bullard,Lake Palestine , Texas
Dinosaur
Get a “dinosaur” circuit board. Easy to self install.
Search on site for it.
I always keep a supply of stimulant handy in case I see a snake ......which I also keep handy
Lafitte is offline   Reply With Quote
Old 08-08-2024, 04:35 PM   #3
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
First make sure that the wire that supplies the spark electrode is not shorted anywhere, if it is it won't allow the spark to reach the electrode. Also clean any spade connectors that may be present. Finally, make sure the surface that the spark is supposed to jump to is grounded.
Brian
ITSNO60 is online now   Reply With Quote
Old 08-08-2024, 06:41 PM   #4
Sioux Falls , South Dakota
After you have cleaned the spade terminals make sure that the screw is actually tight. Don't ask how I know this. <grin>
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Old 08-08-2024, 08:18 PM   #5
2020 23' Flying Cloud
2019 22' Sport
Sebastian , Florida
I had the same situation on our previous trailer, a 2019 Sport. I had to replace the board. As Lafitte says, Dinosaur is best. LOTS of post a couple of years ago about these. Shame on you, Dometic!
But you can try the cheap fixes first…
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 08-08-2024, 08:22 PM   #6
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
after 3 failed boards in my last sport 22fb, the dinosaur circuit board was installed and worked fine for the next 4 years. never an issue
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is online now   Reply With Quote
Old 08-09-2024, 09:37 AM   #7
Susanville , California
Response
I also have a 2017 25ft. International Serenity and have had problems with the same WH. I have found that while in transit the ingniter and pilot get misaligned and need a simple adjustment to correct.
P. Wee is offline   Reply With Quote
Old 08-09-2024, 10:43 AM   #8
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
Buy a new igniter. They are cheap and are a common fail item. You already mentioned corrosion on it.You should probably test with a multi meter to see if in fact there is a current to the electrode, but in all honesty you have spent more of your time cleaning and gapping and reinstalling than what the part cost. It's a common replacement when I am out working on these units. That and the thermal fuse are typical fail points. Others have mentioned the board. If you do replace a board anytime in the future the Dinosaur board is the way to go. Unless the igniter isn't getting a signal from the board, I doubt from what you have described its a board issue. Good luck.
silverlabs is offline   Reply With Quote
Old 08-14-2024, 11:49 AM   #9
2020 30’ Globetrotter
Shell , Wyoming
Fully agree. Had ignition issues - gone with the dinosaur circuit board. Much nicer construction.
CLOUD9WYO is offline   Reply With Quote
Old 08-16-2024, 08:11 AM   #10
West Lake Hills , Texas
+1 for the igniter and the dinosaur board. Both easy to install. I bought two igniters and carry the extra one as a spare.
Fungus is offline   Reply With Quote
Hot hot hot rambler1970 1956 - 1965 Caravel 4 10-04-2023 05:16 PM
Cold, Hot, Cold, Hot, Cold Hot thiel Water Heaters, Filters & Pumps 5 07-15-2023 12:12 AM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
