Old 06-05-2020, 08:13 AM   #1
2020 25' Flying Cloud
Knoxville , Tennessee
How does it work
Rank newbie here, so bear with me.
Iím confused as to how the propane systems for the refrigerator and water heater are reactivated after being shut off for traveling or storage.
I assume they automatically reignite but want to be informed on the subject.
Gibson3798 is offline   Reply With Quote
Old 06-05-2020, 10:58 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
The tanks don't have to be shut down for towing.
When they are shut off for storage I usually get a butane match and click away at the stove until the burner lights to purge the air from the lines.
After that the fridge and water heater usually light after several tries.👍
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"My sex life is like a Ferrari...I don't have a Ferrari."
Dino Longuini
Tahawus....🌥
ROBERT CROSS is online now   Reply With Quote
Old 06-05-2020, 11:39 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yes to all of the above, but to get my refrig to light the first try, I run the furnace first, for just a minute, which pulls propane up into that portion of the piping. Until I shut off the tanks, everything stays ready to light, then.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-05-2020, 12:09 PM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Yep, those are the things which work. I've also stumped myself by opening the tank valves too quickly. I learned that a slow, easy valve opening works best.
Linda Heuer, Past President, Spirit of Virginia Club
Greg Heuer, President, Spirit of Virginia Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 06-06-2020, 09:23 AM   #5
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Yep - all above - for us the end point is the stove once lit all work
La Dolce Vita Brick & Mona
We're Married With Airstream
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 06-06-2020, 10:46 AM   #6
2016 30' Classic
Battle Ground , Washington
Tanks Turned Off
I think it's the law in most states that you turn off propane tanks when towing. Let me know if I'm wrong. I think it's a good idea.
Stews is offline   Reply With Quote
Old 06-06-2020, 10:51 AM   #7
lsbrodsky's Avatar
Nope. A few bridges and tunnels require it, but not the highways.
Larry
Old 06-06-2020, 12:29 PM   #8
Gulliver72's Avatar
2015 25' FB Flying Cloud
Barnstable , Massachusetts
We need to turn refrigerator off, then on again after propane lines are purged. We always travel with tanks on.
Gulliver72 is offline   Reply With Quote
Old 06-06-2020, 12:46 PM   #9
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Larry
Some ferries and gas stations too.
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
hhendrix is offline   Reply With Quote
Old 06-06-2020, 01:02 PM   #10
Mollysdad's Avatar
I have never turned off the propane tanks. Even in storage.
When traveling, I switch the fridge to gas, and arrive with nice cold food!
Originally Posted by hhendrix View Post
... gas stations too.
Who turns off the propane for getting gas?
I'm reminded that some stations also ban the use of cell phones while pumping gas even though there's never been a case in the world where a cell phone caused a gas explosion.
Now if you want to smoke while gassing up, I have a problem with that!
Old 06-07-2020, 12:11 PM   #11
The Panhandle , Idaho
Uh, oh.
Uh, oh. Let the debate begin.
Many people do and I expect there will be several that will weigh in here on this matter. I don't turn our tanks off either when gassing up. Why? Because gas fumes are 3 to 4 times heavier than air. They can spread over long distances and they tend to accumulate in low places. But they are not going to climb up the side of the trailer to reach the fridge access panel at the exact time the fridge is reigniting.
As for cellphone usage at the gas station a quick search will reveal numerous sources stating that using your cell phone does not cause the fire/explosion when pumping gas. What does is static electricity, often picked up when you slide back into your vehicle to get your phone once you've started pumping gas. You should always ground yourself to discharge any built up static electricity when you exit the vehicle at the gas station.
I know some will disagree, and that's okay.
Hoagie '59
Hoagette '57
Whitney and Tobin -- The Aussie Posse
Hoagie is offline   Reply With Quote
Old 06-08-2020, 09:34 AM   #12
1986 31' Sovereign
Miami , Florida
How does it work
I donít shut the tanks off when I fuel. With my fuel filler door next to the diesel pump, my refrigerator vent is 22í away. It is also several feet off the ground.
In all my years of towing I have shut the propane off a handful of times: Chesapeake Bay Bridge Tunnel, NC Ferries, Cape may/LLewes ferry, a tunnel in Baltimore whose name I canít remember... I think thatís about it.
Within minutes someone will chime in that I am destined to die at any moment and , worse, Iíll probably take out a bus full of orphans in the explosion.
Then someone will offer the scenario that ďin a rollover, your propane lines will be ripped open and the resulting explosion with flatten an entire countyĒ. Except, of course that if the valves on your propane tank detect zero back pressure, they close.
All in all, most of us tow with the reefer on propane. To the best of my knowledge there are not blackened craters full of molten aluminum scattered about the landscape...
new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Work Platform for Roof Work Bubba John Roof 18 08-02-2015 09:16 AM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Prep Work vs Finish Work Nolavalkyrie Vintage Kin 5 10-03-2013 03:11 PM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
How does this work??? thenewkid64 General Motorhome Topics 7 07-21-2003 08:58 PM
