Old 04-18-2025, 02:50 PM   #1
2018 22' Sport
Salem , OR
Question Hot water tank pressure release valve super tight
My plan was to remove the valve, pour in 50-50 solution of vinegar and water, leave overnight, then drain and flush thru to drainage hole. MY PROBLEM: I'm afraid I will break something, the amount of pressure on my pipe wrench to turn the valve was amazing, and it only moved a 1/4 turn or less before I panicked and gave up. Should I power on, or what? Thanks.
Rob Gramenz is offline   Reply With Quote
Old 04-18-2025, 03:01 PM   #2
Turkeybaster's Avatar
2008 27' Classic FB
Central , New Jersey
I had the same experience. My pressure relief valve doesn’t seal that great and drips at times. My plan was to replace it. However when I put a wrench on it, it wouldn’t budge. I used a bigger wrench and it still wouldn’t budge. I too felt like I was going to break something if I cranked on it any harder or used an even bigger wrench. So I just left it as is and tolerate the periodic slow drip.
Maybe someone knows an effective method for removal.
TB
2008 Classic Limited 27FB “The Chief”
2017 F-350 6.7L Platinum
Turkeybaster is offline   Reply With Quote
Old 04-18-2025, 03:13 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
1) Spray the threads of the valve with a good penetrating oil and let it sit five plus minutes. 2) Slightly tighten the valve, spray the threads again, and let it sit five + minutes. 3) Loosen the valve (slightly) and spray the threads again as you loosen it.
Spray and repeat a little at a time. You may have to 'work' it back and forth a number of times to get it to start turning freely. It takes patience.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-18-2025, 03:44 PM   #4
"Cloudsplitter"
Just us...
We use it to help drain for winterizing.
I don't see any reason why you couldn't pump your concoction into it.
Old 04-18-2025, 05:53 PM   #5
Bigventure's Avatar
2021 30RB Classic
2016 30' Classic
Hinckley , Ohio
Hoser
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
Bigventure is offline   Reply With Quote
Old 04-18-2025, 07:37 PM   #6
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
It's the hardened pipe dope used during assembly. Heat will help soften it somewhat. When you replace, either clean the threads and use fresh dope or replace the valve with fresh dope.
Brian
ITSNO60 is offline   Reply With Quote
Old 04-18-2025, 10:55 PM   #7
2018 22' Sport
Salem , OR
OK, I'll try that. I believe I've got a bit of patience left over from my last project.
Old 04-18-2025, 10:57 PM   #8
2018 22' Sport
Salem , OR
No doubt you are right; around the valve was some pretty crusty material; more of it is doubtlessly "gluing" the valve in place.
Old 04-19-2025, 09:11 AM   #9
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Keep in mind that the tank is only just so strong. You can indeed put enough force on things to do damage. It really was not designed to be taken apart and put together multiple times. You have risk of issues both pulling stuff off and when putting it back on again.
Better to do as noted above and just pump the "stuff" in through the normal water path. You use a bit more vinegar .... it's way cheaper than a new tank. The whole project will be over a lot faster as well.
Old 04-19-2025, 11:21 AM   #10
2017 25' Flying Cloud
Woodway , Texas
Relief Valve Removal
We had to replace ours only after about a year when it started leaking. The aluminum of the tank and brass of the valve don't play well together and everything becomes really, really stuck in short order.
I used a propane torch and applied a lot of heat to the valve which helped in removal.
When installing the new valve, I just used a lot of Teflon tape and hand-tightened the valve until it was snug and oriented 'downward' as before.
If you do need to open the tank for occasional flushing, use the Nylon drain plug, also reinstalling it with Teflon tape.
emelaich01 is offline   Reply With Quote
Hot Water Heater Release Valve Question tjwoods1 Water Heaters, Filters & Pumps 11 08-28-2022 09:00 PM
Have to back up a very tight 150' driveway into a tight space... front hitch? starkruzr Towing, Tow Vehicles & Hitches 57 07-01-2020 10:38 PM
Brakes, How tight is too tight? rhutson Brakes & Brake Controllers 5 03-15-2012 12:48 PM
How tight is too tight? Alden Miller Awnings 16 06-01-2006 09:09 PM
