Turn you on board pump on and run all your faucets. You may still have air in the lines. Try several things, run the outside shower, run the inside faucets, open the low point drains briefly, run both the pump and the city water at the same time.
True that mixing valve screen could be clogged, but I'd sure try the onboard pump and see if there's not an air in the lines issue.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
