I would use a half round file, available at most home supply stores if you don't have one, to slowly remove some of the shower wall. The file should be fairly fine and go slow. Very carefully remove the pin, so it dosen't drop in the wall!! A dremel tool with a fine metal side cutting bit works well, but more care is required. Take your time and you should have no problem. Been there, done that!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
