Originally Posted by TG Twinkie
If you use the winterizing kit to put the mixture in to the water heater.
Make sure the WH is empty and the drain valve is in place.
Set 3 gallons of vinegar and 3 gallons of water where you can pump the 6 gallons into the WH. Using the winterizing suction tube
Open only the closest hot water faucet to the WH.
Make sure you are not in the winterizing mode with the valve(s) at the WH.
Start the pump. Run it until you see water flowing steadily out of the hot water faucet.
Let the mixture set.
When ready to flush.
Drain the WH.
Reinstall the drain plug.
Switch the winterizing valve at the pump to the house water position.
If city water is available wait to install the plug and flush the tank using city water.
Once the tank is flushed. Open the valve and flush what little mixture remains in the pipes.
You should be good to go.
Oh! Close the faucet and shut the pump off.
I do pretty much the same, but just open the pressure relief valve instead of the nearest water tap. Little vinegar gets into the lines.
BTW, it's a good idea to either open the pressure valve or a faucet before draining the vinegar solution. The vinegar and scale can cause a pressure build up... Ask me how I know.
