Old 02-01-2024, 09:28 AM   #1
1985 29' Sovereign
Tofino , British Columbia
Gas Valve Atwood 91043 needs to be replaced.
Hi all,
We own a 1985 Sovereign and we need to replace the water heater gas valve.
We are having a hard time finding the right one.
The gas valve is a AT WOOD NO. MPD - 91043 and the people from RobertShaw are saying that: It’s a White Rodgers valve
The only valve that we have for some of the Atwood tanks is 110-503 / ½” pipe inlet and 3/” pipe outlet plus a ½ to 3/8 pipe reducer – If your pipe sizes match up then 110-503 would work for you – LP tanks have different odd fittings so make sure on the pipe size before you buy one...
I've also found one Atwood 91602 Aftermarket RV Pilot Water Heater Gas Control Valveon on the https://pantherrvproducts.com website.
So now I am a bit confused about finding the right product!
Thanks in advance!
PP
PP Jutras is offline   Reply With Quote
Old 02-01-2024, 01:46 PM   #2
1986 29' Sovereign
Southern , California
According to etrailer this is the replacement valve.
https://www.etrailer.com/question-357741.html
Available from Amazon
https://www.amazon.com/Atwood-91602-...ustomerReviews
Im2bent is offline   Reply With Quote
Old 02-01-2024, 11:10 PM   #3
1985 29' Sovereign
Awesome! thank you very much.
Frustrated! Replaced antenna to Jack, replaced connections....still nothing. 09 27 jholder Audio, Video & TV 10 06-10-2018 09:05 PM
Atwood 6 gallon water heater -- gas valve issues MR AIRSTREAM Water Heaters, Filters & Pumps 6 07-06-2016 06:34 PM
Need help with Gas Valve Replacement Atwood Mdl G6A-6E Re-Pete Water Heaters, Filters & Pumps 15 09-24-2015 08:41 AM
Atwood 91043 to 91602 Britbat Water Heaters, Filters & Pumps 0 04-16-2015 07:49 PM
Atwood gas valve cost? Mike76251 Water Heaters, Filters & Pumps 4 10-03-2003 06:09 AM
