05-13-2025, 09:28 AM
2002 25' Classic
Kalama
Gas heated hot water
Our start cycle is normal, but it stops heating before reaching the set temperature. It then begins a restart, which also fails. Other than cleaning the orifice, are there some likely TS tips I can try to diagnose/Rx our heater?
05-13-2025, 11:04 AM
2010 30' Classic
Warren
, Manitoba
Good possibility that thermostats have failed. They are easy to replace.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
05-13-2025, 03:59 PM
1994 30' Excella
Mississauga
, Ontario
The orifice for the gas is a ruby so don’t use a pin to clean. It will ruin it. Soak in alcohol. That’s it. Like said probably a temp sensor on the tank.
Al and Jean
BRN 3845
TAC ON-3
05-13-2025, 05:06 PM
2002 25' Classic
Kalama
CBWELL, Big Al - thanks for the assists. Five videos later, I found one that included gas dynamics. After disassembly and some housekeeping that really wasn't necessary, the culprit turned out to be a misadjusted airflow tube. Once I was taught its function and proper adjustment, we're back to nominal again.
Both of your suggestions were included, referenced in the videos and checked. Happy camping again!
05-14-2025, 11:44 AM
2015 27' Flying Cloud
Portland
, Oregon
Can you post the link to the video?
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
05-14-2025, 12:51 PM
2002 25' Classic
Kalama
w/in these
Browsing history showed these. Not sure which one ultimately educated me,
but they'll get you in the ballpark.
05-14-2025, 02:51 PM
2017 25' Flying Cloud
Woodway
Also a good idea to check your airflow tube adjustment with the door to the unit closed. Somehow, ours would spit and sputter but when the door was opened, it 'settled down'.
Opened the tube up just a tad more, closed the door and it worked perfectly. Had this same problem with a Jayco we owned prior.
05-14-2025, 10:27 PM
2002 25' Classic
Kalama
The takeaway
Good point - What's important, is that proper gas operation gives a quiet, blue flame... the result of the correct gas/oxygen ratio. Changing elevation, changes that ratio (as does opening/closing the access door. If it spits and coughs, or sounds like a jet engine, a tube adjustment is required.
05-18-2025, 04:38 PM
2016 30' International
redondo beach
Since we go from sea level to 6,000 + feet we carry a thingy tool and adjust air flow a lot for that clean burn.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
