Old 05-27-2024, 06:36 AM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
e6 error message: Girard instant hot water system
while taking a shower, the display beeps and shows a E6 error
then it stops making hot water
i have turn off/on to get it to work
why do i get this message
how do i stop it?
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is online now   Reply With Quote
Old 05-27-2024, 07:18 AM   #2
Trekers's Avatar
2022 30' Flying Cloud
OKEMOS , Michigan
That's an excessive temp code. What temp are you setting hot water at? Are you using only hot water or mixing with cold? What is your water pressure like? What's your incoming water temperature like? Is the exhaust fan on the Girard running when the unit kicks on? All can impact an E6 code. - Ari
Trekers is offline   Reply With Quote
Old 05-27-2024, 07:19 AM   #3
2022 27' Globetrotter
Bethlehem , Pennsylvania
This is the overheat error. Generally caused by too high of input temperature. Is your water hose in direct sun light? Or are you in a really hot place?
Merlintiaga is offline   Reply With Quote
Old 05-27-2024, 08:38 AM   #4
1988 32' Excella
Robbinsville , New Jersey
Yes, proof it is not a "hot water heater" it only heats cold water.
Wazbro is online now   Reply With Quote
Old 05-27-2024, 09:35 AM   #5
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
If your flow restrict valve located inside the trailer on top of the Girard is adjusted slowing the water flow to much in hot weather it could trigger that vide. Try turning the knob opening it up more.
Honestly we had so much frustration , wasted water when on the tank and ice cold showers with the Girard that we had ours removed and a Truma installed. It’s been perfect showers ever since worth every dime.
Life is a Highway is offline   Reply With Quote
Old 05-29-2024, 08:31 PM   #6
waninae39's Avatar
NCR , Ontario
i have a return water system, at times it thinks the water is too warm, thus i get that message. now i simply shut the unit off then on. error goes away
WBCCI# 21212
Old 05-30-2024, 08:39 AM   #7
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
In researching a return water system, I read where the return can't go back to the pump or the water heater will overheat, it has to go to the freshwater tank fill line. How is yours connected?
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is online now   Reply With Quote
Old 05-30-2024, 02:37 PM   #8
waninae39's Avatar
NCR , Ontario
this is our schematic
it works very well
it works just like the trauma system but cost $3000 less to make
Name:	new 4-50p.jpg
WBCCI# 21212
Old 06-05-2024, 09:41 AM   #9
Fayetteville , Arizona
If youíre running one tank with the 2nd tank shut off and the other went empty, you get the code. You have to have LP for it operate.
akarakos is offline   Reply With Quote
Old 06-05-2024, 10:07 AM   #10
2024 27' Globetrotter
Kathleen , Georgia
Who did your “return water system”? Thanks
jalexbell is offline   Reply With Quote
Old 06-06-2024, 03:53 AM   #11
2023 27' International
Oceanside , CA
Confirm that the "return" is going back into the fresh tank and not just back to the pump. I have a Showermeiser, set the temp to 109F and turn the shower on full hot with zero issues...
O-side Jimmy is offline   Reply With Quote
Gerard instant hot water - strange problem mbronto Water Heaters, Filters & Pumps 8 01-29-2023 07:11 PM
Girard E3 Error Code steilkurve Water Heaters, Filters & Pumps 9 09-03-2022 11:47 AM
Newbies: our instant hot water heater just stopped working! sampson Plumbing - Systems & Fixtures 6 05-18-2015 07:28 PM
Instant hot water? TikiPatrick Water Heaters, Filters & Pumps 1 11-19-2013 05:59 PM
Instant Hot Water ALANSD Water Heaters, Filters & Pumps 7 12-15-2008 11:13 PM
