Old 12-31-2018, 03:13 PM   #1
2005 22' International CCD
Camarillo , California
Draining Water Heater
So I'm certainly a newbie here and any help will be very much appreciated. We just returned from our first trip out in our "new" 2005 22ft International CCD. Everything went extremely well. Not a single glitch. My wife and I are hooked. My question is now that we are back should I drain my water heater until needed again?
MarkBeck is offline   Reply With Quote
Old 12-31-2018, 03:23 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We drain our water heater after every trip, unless we will be leaving again within a week or two. If we think the last water used might have high iron content, we drain it right away even if we will be using it again soon.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 12-31-2018, 03:32 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
If you feel it's needed in your area by all means do it.
We don't after each use here in WNY, just for Winter storage.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 12-31-2018, 03:39 PM   #4
Kevin245's Avatar
We drain ours out of habit. I replaced the plastic plug with a ball valve so the process is fairly simple.
William C. Swinney
Old 12-31-2018, 03:42 PM   #5
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
You might find it handy to replace the drain plug with one with a valve if you frequently go on short trips.
daleyocum is offline   Reply With Quote
Old 01-02-2019, 12:27 PM   #6
Thanks for the advice. I see there are different opinions on this (like most other) topic. Think what I will drain it this time and see how much sediment is in the tank and from there decide if I should drain it after each trip.
Water heater draining root4wings Plumbing - Systems & Fixtures 3 10-28-2018 04:34 PM
Water draining from the belly pan Roadtoaster Belly Pans & Banana Wraps 5 06-24-2015 04:09 PM
Draining water heater? Will_Brule Water Heaters, Filters & Pumps 20 09-21-2013 04:16 PM
draining water heater John Greenlee Winterizing, Storage, Carports & Covers 15 12-30-2005 03:04 PM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
