Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-28-2021, 11:29 AM   #1
Tahoe Vista , California
Draining hot water tank fully?
So I drained the hot water tank on my 2009 cloud, but just wanted to make sure all the water is out. I pulled the outside plug and let all the water out as well as all the other low point drains on the trailer. I also blew out the fresh water lines with an air compressor.
Is there anything else needed to be sure the hot water tank is fully drained?
Thank you!
Double J is offline   Reply With Quote
Old 11-28-2021, 12:59 PM   #2
aftermath's Avatar
Spokane , Washington
It doesn't have to be totally empty. Water causes damage when it freezes and expands. With the tank almost empty any small amt of water left will have plenty of room to expand. No damage, no worries.
aftermath is offline   Reply With Quote
Old 11-28-2021, 01:33 PM   #3
ITSNO60's Avatar
Tucson , AZ
The way I understand is that the water heaters with electric elements don't drain all the way, this is to keep the element submerged and protect it should it be energized before the tank is full. That said, when I did what was probably the first flush on my 10 year old unit I did multiple flushes then hooked a piece of plastic tubing to a shop vac and stuck it in the drain hole pulling out the rest of the water and a surprising amount of white bits of calcium. If you do this make extra sure it doesn't get energized before filling by turning off the circuit breaker.
Brian
ITSNO60 is offline   Reply With Quote
Old 11-28-2021, 02:05 PM   #4
2017 28' International
Jim Falls , Wisconsin
Agree. No need to have the water completely out of the water heater. The only thing one really may need to do is flush it out good with a wand to get any sediments out.
Daquenzer is offline   Reply With Quote
Old 11-28-2021, 05:34 PM   #5
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Yes, this.
thewarden is offline   Reply With Quote
Old 11-29-2021, 10:10 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Just a reminder - NO antifreeze in Hot Water Tank nor the Fresh Water Tank
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 11-29-2021, 10:21 AM   #7
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you do not pull the drain plug in the bottom of the water heater, you can have freeze damage. I know folks who have had this happen to them.
Old 11-29-2021, 10:26 AM   #8
abbotsford , British Columbia
i always go for a drive with the plug out and drain open. that gets rid of it and evaporation does the rest
telcoman is offline   Reply With Quote
Old 11-29-2021, 10:43 AM   #9
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
You can use your air compressor to pressurize the lines and remove the water heater drain plug to blow out the rest of the water if you choose. When I do this, I unplug the electronic connector to the water heater to ensure that I don’t accidentally burn out my heater element in an empty tank.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 11-29-2021, 10:44 AM   #10
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
The Atwood manual spells out how the little water remaining in the bottom of the water heater won't cause any problems with freezing due to the shape/orientation of the tank. It's a cylinder laying on its side, and the curved shape of the bottom of the tank mean that the water remaining there cannot create any pressure as it freezes. No pressure, no problems.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is online now   Reply With Quote
Old 11-29-2021, 10:44 AM   #11
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I was going to suggest that. I don't have to winterize, but from research, it was best to open all valves to prevent any possible pressure build-up from either liquid or air.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 11-29-2021, 11:31 AM   #12
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Richard's giving good info but here's the rest of the story this is from the Atwood service manual, the last sentence in point 4 covers the remaining water.
"3. After draining the tank, because of the placement of the drain plug, approximately two quarts of water will remain in the tank. This water contains most of the harmful corrosive particles. To remove these harmful corrosive particles flush the tank with either air or water. Whether using air or water pressure, it may be applied through the inlet or outlet on the rear of the tank or the pressure temperature relief valve. (If using the pressure temperature relief valve the support flange must be removed). The pressure will force out the remaining water and the corrosive particles. If you use water pressure, pump fresh water into the tank with the assistance of the on-board pump or use external water for 90 seconds to allow the fresh water to agitate the stagnant water on the bottom of the tank and force deposits through the drain opening. Continue repeating adding water and draining until the particles have been cleared from the water remaining in the tank.
4. Replace the drain plug and close the pressure temperature relief valve. The approximately two quarts of water remaining in the tank after draining
will not cause damage to the tank should freezing occur."
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 11-29-2021, 03:07 PM   #13
Antsville , FUBAR
Gary
I use air thru the pressure relief valve with my MacGyver'd blaster adaptor.
Old 11-30-2021, 08:35 PM   #14
Gary
Thanks all! I feel better about the remaining water left in the tank now.
Also, good to know about needing to flush the tank out as I didn’t do that. I will need to remember to do that when I de-winterize in the spring.
Thanks again!
Old 12-05-2021, 11:45 AM   #15
1976 Argosy 26
Henderson , Kentucky
Images: 21
Good info. Remember to raise opposite side tires to increase discharge from WH drain plug.
Be Safe. Mitch
Ky76Argosy is offline   Reply With Quote
Old 12-05-2021, 06:59 PM   #16
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Open the pressure relief valve also. I leave the plug off for the winter…just in case.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 12-05-2021, 07:08 PM   #17
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I put the plug back in to keep out the critters.
sheriff1 is offline   Reply With Quote
Old 12-05-2021, 07:45 PM   #18
1 Rivet Short
1989 25' Excella
32 years…no critters. Maybe I’m doing something wrong?
Getting hot water from cold lines (after draining heater?) wmb Water Heaters, Filters & Pumps 15 01-21-2019 09:50 PM
Hot water draining issue .... Pops1814 2016 - Current Classic (all lengths) 6 08-08-2017 08:54 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 02:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
Water Tank Draining trippy 2005 - 2010 Safari 1 09-13-2006 08:31 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
