Originally Posted by jcm14246
1994 Excella with Atwood hot water heater
Someone modified the heater to operate on electric by replacing the drain plug with an insert that is wired to 110 volts.
Any other way to drain the tank.
If you are draining your water heater when you are draining the rest of the plumbing by blowing it out with compressed air you don't need to remove any plugs.
The cold water inlet is on the bottom of the tank and the hot water outlet is at the top of the tank. So the tank will blow itself dry if you manipulate the valves correctly.
What I do is open the hot and cold water low-point drain valves and connect air pressure to the city water inlet. (I only run 20 PSI). Blow the water out of the system until most of the water is out. (Air coming out of the low point drains with just a few spurts of water now and then.)
Then I open the faucets, shower valve, toilet flush valve, etc. one at a time to blow the water out of those lines.
Finally, close all hot water faucets and the hot water low point drain so pressure can build up in the hot water side of the system. Any water remaining in the water heater will be blown out the cold water low-point drain.
I have been winterizing our trailer this way for 10 years and it works for me.
