Dometic WH shuts off after 5 mins
2020 airstream flying cloud 25 front bedroom. Dometic/atwood 93755 dual gas electric 6 gallon. Dewinterized a few days ago and ran all systems. All looked good. Fired up the gas/electric water heater checked a few minutes later, water was good and Hot called it good. Check it again today and both electric heating element and or gas burner shut off after five minutes and only come on again if I turn the gas/ electric switchon again, then only stay on again for 5 mins. Yes, bypass is in correct position. Water pump running fine. No blown fuse or tripped breaker. No air trapped- ran at least 6 gallons trying to troubleshoot. Thermocoupler looks good took it off, cleaned ends and replaced. Thermostat(s) or circuit board? Something else?
Appreciate it.
