Old 11-03-2023, 12:32 PM   #1
2020 25' Flying Cloud
Woodinville , Washington
Dometic water heater propane flame goes off/on
GE 9 EXT is the model number. The video below capture the heater flame out and re-ignition. Water heats just fine on electricity but takes longer on propane.
Water Heater Video
Can someone help me diagnose this and possibly suggest repair/solutions?
TIA
Nishad is offline   Reply With Quote
Old 11-03-2023, 12:54 PM   #2
2019 25' International
Pinehurst , NC
Flame going out on water heater
Take the mixing tube etc. apart, clean the interior (cob webs, dirt) put it back together and relight. When lit loosen up screw, shown in your video and adjust mixing tube (slide in slot) until you get a good flame i.e. mostly blue showing.
Slietesa is offline   Reply With Quote
Old 11-03-2023, 12:55 PM   #3
2019 30' International
Pennsylvania , Pennsylvania
First thing I'd try is....loosen the little screw on that slotted tube and close the gap to half way. It may just be getting too much air. Slide it to where the flame burns more steady....
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 11-03-2023, 02:25 PM   #4
Thank you, both!
Mixing tube was clean. I need to adjust the fuel/air mixture as recommended. I ended up at 2/3rd way closed.
Thank you!
Old 11-03-2023, 03:29 PM   #5
Thank you!
That sounds about right!
Old 01-08-2024, 10:13 AM   #6
The issue is back again...
... with a twist. The heater turns on and off for 3 times when first started. The red light comes on. After waiting for a minute and restarting the water heater it works fine.
Here's a partial video.
What should be my next steps to investigate and fix? Thanks!
House battery goes off when engine is turned off Lily&Me Sprinter and B-van Forum 6 08-06-2018 04:50 PM
hydro flame won't flame 123f5 Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-12-2010 09:05 PM
Furnace goes on, TV goes off whacksplat General Repair Forum 11 05-17-2009 07:33 AM
Open Flame Propane Heater Gas Monitor Results Pick Off Topic Forum 8 01-10-2004 09:25 PM
