Old 08-17-2022, 03:48 PM   #1
2019 27' Tommy Bahama
Healdsburg , California
Dometic GE9 EXT water heater not getting hot
A couple days ago after we got to camp and hooked up to city water our water pressure release valve was leaking. We turned off the water, opened up all the faucets then opened the valve and it stopped. We then realized are hot water was no longer working. With closer inspection, in the light of day, it appears that the wiring for that heater, in the same area, got wet. The plastic coating was wet inside so the wires got wet when the valve was leaking. We ordered and installed a new thermal cut off. We checked all the breakers and shut the main on and off a few times. When we turned on the propane switch for the water heater it fired up and ran for about 4 minutes then shut off, water was only warm. A few hours later the water heater fired up again but again only for a few minutes. This continued for the rest of the day. Water is just not getting hot. (BTW we camp every few weeks and have never had any hot water issues)We called the dealer they were no help and can't even look at it until October. We called Dometic and they wouldn't advise us due to liability concerns. We are quite handy and have fixed many issues watching youtube videos... We just need some advice on what could be causing this issue. We are thinking either the thermostat, not adjustable, or the control board? Thanks so much in advance!
CJSutton is offline   Reply With Quote
Old 08-17-2022, 05:21 PM   #2
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Dinosaur Control Board
Sounds like the control board because of the intermittent service. Try the Dinosaur UIB64 #91346. I carry an extra with me in the parts bin.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Tankless Water Heater Issue - Not getting hot in shower hlmmay05 Water Heaters, Filters & Pumps 32 04-13-2022 10:29 AM
Trading tanked hot water heater for tankless hot water heater? robwolff3 Water Heaters, Filters & Pumps 16 11-11-2021 09:10 AM
Getting hot water from cold lines (after draining heater?) wmb Water Heaters, Filters & Pumps 15 01-21-2019 09:50 PM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 02:21 PM
