Old 09-24-2022, 05:24 PM   #1
Tahoe Vista , California
Do I need to drain hot water heater for this leak?
Always something. Testing systems and found this leak from a connection point on a pipe that connects directly to hot water heater. Not 100% sure, but doesn’t look like there is any white thread seal tape on these threads like the other connection point to the left.
Do I need to drain the hot water heater and open the hot water low point to drain the hot water line before disconnecting to put some white thread seal tape on?
Thanks for your help!
JJ
ID:	422995   Click image for larger version
Double J is offline   Reply With Quote
Old 09-24-2022, 05:51 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
JJ
That wing nut has a cone shaped grommet under it that gets compressed to seal. No tape or pipe dope needed.
I’d disconnect from water (no pressure) in system and just tighten wing by hand or a slight snug with short handled pliers on the nut a bit and try again.
It is a std pipe to faucet type fitting. Just with that pic you can go to hdwe or home center buy a new fitting and take the grommet out and exchange it. No fitting R&R reqd unless fitting nut is cracked.
Gary
GCinSC2 is offline   Reply With Quote
Old 09-24-2022, 05:58 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
These are the washers/gaskets/grommets/seals which are inside that connection point. Not uncommon for them to be pinched when being connected, leading to a leaky connection. If tightening it as mentioned above doesn't work replacing it is easy.
Oh, and yes. You'll likely have to drain the hot water system at least till it's lower than that joint.
Richard
11018
richard5933 is offline   Reply With Quote
Old 09-24-2022, 06:11 PM   #4
Thanks so much you guys! I did try tightening it, but only lightly as I did not want to break something. I will try to tighten more and see if the works and if not an trip down to Ace it looks like.
Seems to only leak when I have the hot water heater turned on. I turned off the hot water heater when I saw the leak and will wait until cool to empty. Do you think I need to drain the low point hot water line too or will just the hot water heater be enough?
Appreciate the help!
Old 09-24-2022, 06:16 PM   #5
1994 25' Excella
Only needs to be drained to below the leak. Open the low point if necessary, as well as a hit water tap.
Richard
11018
Old 09-25-2022, 11:04 AM   #6
2017 25' Flying Cloud
Woodway , Texas
Suggest you first unscrew the fitting, then, making sure that the connected parts line up easily, screw the fitting back on. Sometimes, tightening the fitting further only exacerbates the leak. You want to tighten snug, not tight. Some leaks can be caused by overtightening at installation.
emelaich01 is offline   Reply With Quote
water leak under the hot water heater rbs Fresh Water Systems 11 03-06-2022 07:18 AM
Trading tanked hot water heater for tankless hot water heater? robwolff3 Water Heaters, Filters & Pumps 16 11-11-2021 09:10 AM
1986 Sovereign Water Leak? Hot Water Heater ? Luna18 Plumbing - Systems & Fixtures 0 04-17-2016 10:32 AM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
hot water heater drain plug reelfastgreg Plumbing - Systems & Fixtures 30 11-11-2015 04:29 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
