Old 02-24-2024, 02:21 PM   #1
2023 23' International
Englewood , Florida
Question Best way to attach screen to heater gasket
Starshine is a 2023 23FBT International. I had previously put an SS mud dauber screen over the circular opening for the heater. After a post I went to open the flipper door top look at the rocker switch and was constrained by the special spring which was hooked thru. Removed that but I'd like to permanently attach the screen to the flexible "ring". Considering either E6000 or a 2 part epoxy as I don't want to penetrate thru the gasket. Your thoughts? What have you done?
Name:	SS water heater screen.jpg
englewoodfl is offline   Reply With Quote
Old 02-24-2024, 03:49 PM   #2
Mollysdad's Avatar
How about a spring like original, except to a wire across the interior opening?
Old 02-25-2024, 05:33 AM   #3
Englewood , Florida
Fit issue
The outlet protrudes through the gasket so trying to use a simple solution like a wire won't work. The gasket is also a tight fit to the piping. But this is an interesting idea. Later this morning I'm going to print a big washer measuring ~5" OD and 4 1/2" ID and then try running some very thin wire from the mud dauber guard to it.
Name:	23FBT heater outlet.jpg
Old 02-25-2024, 01:35 PM   #4
Englewood , Florida
Version 1
This is a first pass. Workable - the wire is fine enough to allow the exhaust to still go thru the black gasket. I'll probably put a few dabs of E6000 to hold the ring in place.
Name:	SS heater mud dauber guard (1).jpg
ID:	441387   Click image for larger version
Name:	SS heater mud dauber guard (2).jpg
Best Shade to attach to ZD Awning?? LDF22 General Repair Forum 1 07-15-2019 03:42 PM
help, how to re-attach screen door retainer moparjohn General Repair Forum 2 06-25-2019 05:40 AM
Best way to attach these overhead cabinets? funhouse Cabinets, Counter Tops & Furnishings 1 05-14-2013 04:14 PM
Creative way to re-attach entry door latch WineStream Doors & Locks 14 11-15-2011 06:42 PM
how to best attach cabinets to floor? adwriter73 Cabinets, Counter Tops & Furnishings 8 08-27-2010 04:42 PM
