Old 02-08-2023, 08:13 AM   #1
Boxite's Avatar
2008 22' Safari
BEST ATWOOD Video Troubleshooting/Servicing
i dislike YouTube videographers who stand in front of the camera as movie-star wannabees…and yak and yak …when I want to GET TO THE POINT of the video.
THIS guy has a “git ‘er done” familiarization of Troubleshooting and Servicing your AtWood Water Heater.
ALSO notice he correctly points out that the tank should have a PLASTIC plug. In another thread some folks have bragged they’ve installed metal plugs. Bad.
Kudos to him:
Old 02-08-2023, 08:32 AM   #2
Boxite's Avatar
2008 22' Safari
And Another video showing some common repairs to an AtWood.
Notice the advantage of AtWoods’ ALUMINUM tank. (no anode requirement, better/faster heating than steel, no heavy rusting, rarely rusts thru.)
MY PERSONAL INPUT: IF you find you need to adjust the “gap” on your ignitor/sensor DO NOT BEND the PINs at all. Use pliers to adjust the gap by BENDing the BRACKET which holds the “L” shaped pin. (If you try to bend either pin you risk breaking either the spot-weld of the ground-pin…or the Ceramic Insulator of the L-pin.)
Old 02-08-2023, 10:34 AM   #3
2017 25' International
West Lake Hills , Texas
Excellent videos. Thanks for posting. In another video he explains in more detail how to diagnose the electronics of the water heater.
Interesting trick to remove wires from the pins using a small elbowed screwdriver. Tip under the wire. Elbow acts as a fulcrum.
Fungus is offline   Reply With Quote
Atwood Hot Water Heater No Electric - troubleshooting help? jftompkins Water Heaters, Filters & Pumps 2 06-27-2020 09:37 AM
Atwood Water Heater Troubleshooting tracker Water Heaters, Filters & Pumps 8 10-04-2018 04:03 PM
Questions on Atwood water heater- troubleshooting wierdwiam Water Heaters, Filters & Pumps 0 09-20-2009 01:34 PM
Taking a furnace out for extended servicing wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-11-2007 11:12 AM
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 07:46 AM
