Old 08-14-2018, 06:38 PM   #1
2016 22' Sport
Abingdon , Virginia
Atwood Water Heater/Tank 2016 22FB Sport
I am the relatively new owner of a 2016 Airstream Sport. I need help with accurate identification of the plumbing going into/coming out of my Atwood hot water tank. Bottom line, I do not know when to turn on/turn off which valves (there are 5). I could not get the photo of the tank to upload with the correct orientation. The correct view is one rotation counterclockwise — the “cross” cut in the styrofoam covering to the right, and a horizontal white pipe along the floor surface. Any help will be much appreciated.
ID:	319895   Click image for larger version
May May is offline   Reply With Quote
Old 08-14-2018, 08:59 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Turn the handle between the red and white pipe to be 90 degrees with the pipe.
Turn the bottom handle in the white pipe going into the bottom to be inline with the pipe.
Turn the handle in the red pipe inline with the pipe.
I think the other 2 are drain valves.
2016 22FB Sport Bambi Door Closing Problems jcole 2005 and newer - Bambi all models 34 05-17-2021 02:21 PM
2016 Ford Explorer/22FB Sport Combo Rpatrick16 2005 and newer - Bambi all models 20 06-20-2020 02:36 PM
2016 22FB Sport rear bumper? jman230 2005 and newer - Bambi all models 64 04-26-2020 05:54 PM
2016 Sport Bambi 22FB Tire Upgrade ? jcole 2005 and newer - Bambi all models 7 02-23-2016 07:11 AM
