Old 09-28-2020, 04:41 PM   #1
Worcester , Massachusetts
Atwood Water Heater Part - 23D
Hello,
I have tried to order this part twice. However, I keep receiving the wrong part. I know it is inexpensive and I just tried to order it again. Does anyone have any idea what the part number is and the best place to purchase? Please see the arrow on the photo. Thank you again!
Kbuck1234 is offline   Reply With Quote
Old 09-28-2020, 05:02 PM   #2
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Just go to Camping World..... same size for all the SOBs.
glcmranger is offline   Reply With Quote
Old 09-28-2020, 05:11 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Atwood 98157
Take that old one with you to any RV part store.
Or, any hardware or big box building supply store has pipe plugs. If I can't get the proper one, mine can use a standard 1/2" plastic pipe plug with NPT threads.
https://www.lowes.com/pd/LASCO-1-2-i...E&gclsrc=aw.ds
Alan
Old 09-28-2020, 05:13 PM   #4
2014 27' FB International
Lewisville , Texas
Here you go
This is the OEM product made of the correct material
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
NO NOIZE is offline   Reply With Quote
Old 09-28-2020, 05:47 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
A less expensive option, same material as OEM.
https://www.amazon.com/Fimco-Nylon-P.../dp/B006ERRB0A
https://www.amazon.com/Camco-11630-W...CEKQT7830J4GJJ
US Plastics sells them for $0.67 + shipping.
Alan
Old 09-29-2020, 11:30 AM   #6
2017 23' Flying Cloud
Hampden , Maine
It's a 3/4" nylon thread plug, available at any rv supply outlet.
airmaine is offline   Reply With Quote
Old 09-29-2020, 01:39 PM   #7
Thank you!
Old 09-29-2020, 04:01 PM   #8
ScottNDee - NoFuFu
ScottOldre's Avatar
2017 28' Flying Cloud
Irmo , South Carolina
option for plug
I havent done it on our new AS yet, but on previous I replaced with pipe fitting to shortwst available, flexible, metal shielded water supply hose, to small valve, to cap at the valve outlet. when I would need to winterize, this was perfect way to drain with out fuss using compressed air at 40 PSI into city water inlet. Will do it to AS soon
ScottOldre is offline   Reply With Quote
Old 10-04-2020, 03:11 PM   #9
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Easy to get
Saw this at a local rv store
Name:	2020-10-04 16.35.57-1.jpg
waninae39 is offline   Reply With Quote
HELP 2015 Flying Cloud 23D Ameri-Kart part numbers please RollFast Waste Systems, Tanks & Totes 1 05-04-2020 03:30 PM
Atwood 8535-IV Furnace part replacement Just RVing General Repair Forum 0 11-16-2018 01:10 PM
How does a Atwood XT water heater make more hot water? Dremel Water Heaters, Filters & Pumps 9 10-27-2018 12:24 AM
Atwood Front Part? Sundance Water Heaters, Filters & Pumps 0 07-18-2007 02:58 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
