Old 02-26-2019, 10:15 PM   #1
2014 27' FB International
Escondido , CA
Atwood water heater making noise after flush
After flushing the water heater and buttoning it all back up, the gas flame became unruly and noisy. Not sure how flushing the hot water heater caused this issue. Any constructive advice is welcomed. Check out the link below for a video of what I was describing.
https://drive.google.com/open?id=1zc...WBKnXTl4Q8t2Td
Thank you.
Dave
This video is currently processing...
dsatwork is offline   Reply With Quote
Old 02-27-2019, 03:58 AM   #2
Long Island , New York
Welcome to the forum, Dave!
Check for spider or maud dauber nests inside the burner tube:
https://www.google.com/search?q=wate...com&gws_rd=ssl
These nests can be small and tough to get out. You can usually remove the tube, blow with compressed air, and ream it out carefully with a small bottle brush, or a cotton hanky rolled up small so it will fit inside the tube. Shoot some compressed air inside the flue/tube which goes inside the heater body while you're at it.
You may have to adjust the burner tube location slighty to get a pure blue flame.
Good luck,
Peter
PS -- Did not watch video . . . keep as much distance from Goo as possible.
atwood 6 Gal LP water heater stop working after 3 months waninae39 Water Heaters, Filters & Pumps 26 09-04-2018 08:10 AM
Water Heater Making a Strange Noise hollycwright Water Heaters, Filters & Pumps 14 01-28-2016 09:40 PM
Help converter making funny noise! purman Batteries, Univolts, Converters & Inverters 5 07-15-2012 09:15 AM
sway bars making a litle noise augier Hitches, Couplers & Balls 4 04-11-2009 05:52 PM
