Old 05-28-2018, 11:12 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
atwood water heater issue
two failed circuit board so far aarrggh!
I've replaced it with a dinosaur UIB64 board
now i'm getting flames out the slot between the gas value and the end of the tube where the flame is.
PLUS, i have always being seeing soot out of the exhaust
the Atwood manual suggested spiders in the tube. i will clean that to remove the yellow flames that randomly appear. i hope that fixes it
BUT how do i adjust the air fuel mixture to remove soot
more air?
less air?
any suggestions?
waninae39 is offline   Reply With Quote
Old 05-29-2018, 12:36 AM   #2
2007 22' International CCD
What you describe is a blockage somewhere between the air shutter (slotted thingie) and the exhaust. It’s basically backfiring because the flame is blocked.
First make absolutely sure the entire flame path from the slotted area out the exhaust is free of wasp and mud dauber nest material. Run a bottle brush through the entire flue, then use compressed air to blow out the junk blowing at the air shutter end only. Wear eye and face protection. There may be flying bits of stuff, dead bugs, etc. Coming your way at high velocity.
If you have to disassemble parts to clean fully, take pictures first. Don’t ask how I know this...
Clean and reassemble. Then the ‘shutter’ gets adjusted, with the flame on, until it is a steady, relatively quiet blue flame. Yellow indicates too much gas, not enough air. Make sure the water heater has water in it for this step!!!!
A tiny adjustment to the shutter makes a big difference. Be gentle and gradual. Tighten the screw gently. It can easily strip out and screw up everything....and make keeping the adjustment set very difficult.
Old 05-29-2018, 07:02 AM   #3
waninae39's Avatar
NCR , Ontario
thank you
i'll go through those steps
Atwood Furnace & DuoTherm Comfort Control issue Daniel LOUIS Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-30-2017 05:43 PM
Atwood Water Heater - Exterior Cover issue D44 General Repair Forum 3 07-23-2017 06:29 PM
atwood 6 gal water heater issue Blizzard523 Water Heaters, Filters & Pumps 0 05-16-2016 07:54 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 07:10 PM
Atwood furnace issue--Help?! Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-01-2005 09:31 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
