Old 03-03-2021, 06:32 AM   #1
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Atwood water heater, gas burner sputtering.
Atwood water heater GC6AA-10E, gas burner sputtering.
Pre-trip inspection includes test firing all propane appliances. When the water heater lit it ran but sputtered. You can hear the sputtering sound from inside.
First, burner tube inspection, clear. Then the U Tube, no debris found. The U Tube (Atwood name) is the U-shaped tube in the tank that the flame goes thru to heat the water.
Next remove the gas orifice and look for small debris, nothing found. Reassembled and test fired, still sputtering.
Then I removed the entire gas valve and went to the work bench. This time I saw a blockage in the orifice, hardened pipe thread compound. I removed the inlet flare fitting after marking its position. The pipe thread compound on the pipe threads had hardened and some debris was in the valve but the filter screen before the gas enters the valve body blocked it from going into the valve body.
The gas orifice threads into an Orifice Holder (Atwood name), it also had pipe thread compound like the inlet connection, it had hardened and some became debris in between the orifice holder and valve body. The gas flow pushed the debris into the orifice. I removed the orifice holder and the compound debris had found a home in the orifice disrupting the gas flow. Picking the old compound out of the valve body and orifice holder threads and cleaning the out debris, carefully applied new pipe thread compound and reassembled.
Soap bubbled the connections prior to testing. Test firing the burner it ran smoothly no more sputtering.
Job requires basic hand tools and testing the connection for leakage.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
atwood water heater burner baffle walleye001 Water Heaters, Filters & Pumps 0 10-21-2016 05:29 PM
Gas Water Heater - Main burner releasing gas without pilot Gasgano1979 Water Heaters, Filters & Pumps 14 01-25-2015 11:45 AM
Sputtering cancels our trip... Buttercup Mechanics Corner - Engines, Transmission & More... 34 03-16-2010 12:58 PM
Sureflow is wheezing and sputtering Sovereign42 Fresh Water Systems 2 10-28-2009 05:35 AM
Sputtering water silvrtwinkie Plumbing - Systems & Fixtures 3 08-17-2005 06:53 PM
