Old 09-24-2018, 10:12 AM   #1
1998 25' Safari
Owls Head , Maine
Atwood Thermal cut off switch
I am looking for some advice on my Atwood G6A-8E water heater. My thermal cut off switch is tempermental, and I would like to have a replacement of hand but the one that Atwood says I should use is not what is on my water heater. I can easily replace the one that is one there now with the same exact one because it has two female ends so unplug and plug back in, no biggie. The one that is suggested has one female end. I have attached photos to explain.
terricrowe26 is offline   Reply With Quote
Old 09-24-2018, 10:14 AM   #2
1998 25' Safari
Owls Head , Maine
I cant post a picture of the one I have.
Old 09-24-2018, 04:57 PM   #3
Martee's Avatar
2017 25' Flying Cloud
Waco , Texas
I believe the thermal fuse was to protect the Atwood heater from any power surge, such as lightning, or hooking up a 30A trailer to a 50A connection. In an emergency where that fuse is being tempermental and connection is intermittent, you could just bypass the thermal fuse until the proper thermal fuse is purchased. Always replace the thermal fuse, with an exact matching thermal fuse. Atwood customer support can be inaccurate sometimes in their advice to customers.
Martee is offline   Reply With Quote
Old 09-24-2018, 05:18 PM   #4
2007 22' International CCD
The thermal fuse is for protection against the water heater thermostat getting stuck and overheating the water to a dangerous temperature. It's designed to blow at a temperature that is usually marked on the body of the fuse. Bypass one at your own risk. If it's being flaky, replace it. You could try re-crimping the spade connections on the thermal fuse and the wiring connectors it plugs into. The thermal fuses usually either are good, or totally open if they blow. Flaky sounds more like a wiring issue.
If the connectors do not match up on the proper Atwood part number, you can correct the connections, just he sure to use the exact same insulated connector that the new fuse requires. Get a spare--better to have the part in your small parts box than wait for Amazon to deliver it...
It has absolutely nothing to do with protection against power surges, over-voltage or other electrical upsets...by the way...
Old 09-24-2018, 05:28 PM   #5
Sag Harbor , New York
Excellent post Rich.
“Bypass . . . at your own risk.””
Peter
Old 09-24-2018, 05:39 PM   #6
Yup. Scalding hot water is NOT a fun thing, and can be fatal in the shower.
Old 09-25-2018, 11:17 AM   #7
Backfortyjoe's Avatar
2019 20' Flying Cloud
Eau Claire , Wisconsin
I have been working on the same Atwood model for some temperamental problems. One problem was the thermal cut off that had a cold solder joint on the spade end. The one that is on there has one male and one female connection on it. On the new ones you can see that they send an extra wire. I would go ahead with it so if there are problems in the future It would be an easy change out. Good luck. Regards, Joe
Backfortyjoe is offline   Reply With Quote
Old 10-01-2018, 02:50 PM   #8
1998 25' Safari
Owls Head , Maine
the one I have has female connections on both ends. The picture of the one I purchased shows it that way, two female end then it comes as you said with one male and one female and a new wire. It does say ( I noticed after I got it) one the website that the product may differ.
Old 10-01-2018, 03:47 PM   #9
A W Warn's Avatar
Two Places , Sticks & Bricks
Originally Posted by rmkrum View Post
The thermal fuse is for protection against the water heater thermostat getting stuck and overheating the water to a dangerous temperature. It's designed to blow at a temperature that is usually marked on the body of the fuse. << snip>>.
I'd like to add one more thing:
If there is a blockage in the burn tube that causes flashback (fire on the exterior of the water heater), the flame will cause the fuse to melt. This will turn off the gas valve immediately, hopefully extinguishing the flame before any damage occurs.
POSITION OF THE FUSE IS CRITICAL!
Keep the new fuse in the original position above the burn tube. The new wire is not used to relocate the fuse.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Laser cut ignition (key) switch tool. RBonney Classic Motorhomes 5 08-20-2016 07:39 AM
1965 Safari hitch wiring cut off Eholland Towing, Tow Vehicles & Hitches 6 10-06-2012 06:47 PM
By pass valves dripped when cut off. Robbie R. Plumbing - Systems & Fixtures 3 12-15-2009 01:10 PM
How do I cut off the engine Tarheel Mechanics Corner - Engines, Transmission & More... 17 11-26-2006 06:55 PM
How does water pump cut off? 26.982 amu Water Heaters, Filters & Pumps 5 02-08-2006 07:40 AM
