03-04-2020, 02:26 AM
#41
Kensington
, Maryland
This is taking a interesting turn. PM (check), Inlet water filter (check), water softener no so much. I get it, softening water will greatly reduce if not eliminate scale in the mechs.
RM I went to school in St. Paul, MN. Yhis uptight fast talking eastern kid got a fast lesson in the peaceful art of getting along and telling a good story. Miss that place alot. PHC show was broadcast from my schools auditorium a number of times...powdered milk!
03-04-2020, 03:52 AM
#42
2024 23' International
South of Austin
If it stops the hard water and my time wasted for a warranty repair every couple of years, it's a cheap investment.
03-04-2020, 04:25 AM
#43
2016 30' Classic
Houston
Agreed! And a positive response. I don't have a need to adjust today - good to know I have that option.
09-01-2020, 08:17 PM
#44
2019 23' Flying Cloud
Greenwood
, Indiana
My Atwood Mixing Valve
Thanks for all the information. When I noticed a changed in my 23FB hot water I found the solution here. Hopefully the pictures illustrate how I had the exact same issue, and how I was able to use data found here to remedy the situation!!!!
05-06-2021, 01:01 PM
#45
2017 27' Flying Cloud
Greer
, South Carolina
Anyone notice on replacement valve that the screen mesh is much smaller then on original ?
05-06-2021, 05:47 PM
#46
South of Austin
No I never touched it after they installed it because it was a warranty repair.
05-12-2021, 03:11 PM
#47
2018 25' Flying Cloud
Springbrook
, Wisconsin
Forgive my missing something but in a number of these photos one can see a diagram on the heater to the right of the mixer with two diagrams, one winterize and one not. The difference being what looks like something is either turned inline (non-winterized) or perpendicular (winterized). To what is the diagram referencing? The mixer valve has nothing on it to turn one way or the other as I can tell.
Thanks in advance for helping clear this up.
12-23-2021, 12:43 PM
#48
Port Colborne
, Ontario
Hi Everyone,
I was amazed at the "gunk" that came out of the mixing valve. In my case removing the valve was a real chore because the valve is in the back of the HW tank but difficult to access
I think that we should all be extremely vigilant about our water systems and keeping debris from accumulating. I am sure the previous owners did not have a water filter and neglected the system.
Going forward I suspect my system will foul up again and I will have to clean it.
I hope everyone has a Safe and Merry Christmas.
Regards,
Keith Stamper
Keith Stamper
Port Colborne
ON Canada
2019 23’ FB Flying Cloud
2018 Ford F-150 Sport 5.0 V8
12-23-2021, 06:26 PM
#49
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Seasons Greetings to you Keith: After reading this thread and following your "no hot water" thread I'm convinced I don't need a mixing valve. I like to mix it at the faucet instead. I understand RV hot water heaters are set scalding hot so we can have more hot water at the faucet by mixing it with cold. The mixing valve does this for us "automagically". If I was traveling with children, then the mixing valve would make sense. But not for old grandpas like me.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
03-07-2022, 01:30 PM
#50
Kensington
, Maryland
David
David, on our first trailer that's what I did and nobody died which leads me to another day another mixing valve.
We have had this trailer two seasons and no issues until today. I've got obvious mixing valve "gunk" signals. Yes I've got a spare, we are AirstreamR's right?
What would be the problem if I remove that darn mesh screen which loves to collect mineral deposits? We did that on the first trailer and no issues.
I run a high quality two stage filter...for the record.
Tempting.
03-30-2022, 11:53 AM
#51
2016 25' Flying Cloud
Cedar Park
I have a 2015 25ft flying cloud FB. Is this valve Atwood part number 90029 universal?
03-30-2022, 02:00 PM
#52
2017 28' International
Jim Falls
, Wisconsin
Before you change the valve have you tried cleaning it by soaking in white vinegar. But that's the one I use. I have a spare on hand just in case I don't have white vinegar.
03-30-2022, 02:01 PM
#53
Jim Falls
, Wisconsin
Tempting.
Did you do that? I'd like to know how it went. I have to clean my screen just about every year. And I run a filter and a softener.
04-01-2022, 01:52 PM
#54
Cedar Park
Thanks much. It must have been very corroded as after the soak there was still no much flow. I did replace and will is the old for a hot water emergency if neede.
05-27-2022, 06:14 PM
#55
2013 23' FB Flying Cloud
Richboro
, Pennsylvania
daboyce49, I hope by now you've discovered the answer to your question, as it's been a while. But, just in case: The valve in the diagrams is that yellow one you see in the same picture(s). It's the bypass valve for the water heater. When in normal use, you want the valve open so the tank continually refills with use. When you're winterizing, however, you don't want your antifreeze to get into the heater's tank, so you close that valve (bypassing the water heater tank) first, before treating the lines with the anti-freeze. Of course, that also means you flush the lines in the spring, before your re-open that valve.
07-01-2022, 03:24 PM
#56
2018 23' Flying Cloud
Peru
Mix It Up
The Atwood mixing valve 90029 needs cleaning every year. Two guys on this forum suggested that and they are right. I cleaned mine last year and with slightly more than five weeks camping and with a Camco water filter (KDF/Carbon RV water filter) installed I still had luke warm water and the Atwood mixing valve was clogged with calcium again.
The valve is good; the filter backflow screen is the culprit.
Here is what I did: I removed the mixing valve but left the filtered screen part in the water tank by using the correct 1-1/16" open end wrench. Then I removed the brass end from the tank. The initial removal was with a propane tank assisted flame with a wet towel as security.
Here is the picture of the SOB part. With the backflow valve in my vise, I was able to use 0000 steel wool to get it cleaned then soaked it in CLR overnight. Blast it with compressed air on installation.
I have added this procedure to my maintenance log for service yearly.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
07-01-2022, 08:20 PM
#57
South of Austin
I use a GE water filter and a water softener now. I don't put hard water into my AS anymore. I had my valve fixed under warranty a while ago and immediately changed to a portable water softener.
No more calcium buildup. ( Plus the house style water filter to eliminate sediment )
07-22-2022, 08:02 AM
#58
PEACHTREE CORNERS
, Georgia
Replacing Hot Water Mixing Valve
Originally Posted by sheriff1
Just completed this project. Don’t order a new mixing valve yet!
Disconnect the cold water in and hot water out. Make sure pressure is released from system first. The silver portion will unscrew from the brass portion that is screwed into the tank. I used an old fashioned right angle adjustable wrench jut putting it on the body of the valve. That leaves the bronze portion into the tank, use a regular socket on that to remove, as I recall 1 1/8”socket. That’s where the problem is. This piece is the anti backflow valve and it has a screen on it that will be plugged with the white junk that forms in the tank. I had to clean mine a couple of times before I got rid of the white junk.
I'm having the same problem after winterizing my 2017 27FB last year. I was able to unscrew the valve by using a pipe wrench (counter clockwise) but am not able to unscrew the backflow valve, not comfortable with the amount of force I'm using and not sure if I need to unscrew this valve clockwise or counterclockwise. Help!!!
07-22-2022, 08:12 AM
#59
Jim Falls
, Wisconsin
Righty tighty
Lefty loosy
It will take some muscle.
You can also take a compressor and blow the valve out from the top. The problem is that you will need to clean the sediment out of the tank then.
08-23-2022, 06:45 AM
#60
2019 27' Flying Cloud
Kansas City
, Missouri
Following.
Had this trouble last weekend. It was our first trip out this year after de-winterizing in the spring. Tried to run the city water thru the hot water heater and that helped some. Will get the flush wand and try to better clean out at home in a week or so. And grabbing a spare mixing valve just in case.
Thank you to all who have posted!
Piggy Bank
