Old 06-27-2020, 08:21 AM   #1
JFTKSU78
jftompkins's Avatar
2017 23' Flying Cloud
Olathe , Kansas
Atwood Hot Water Heater No Electric - troubleshooting help?
2017 FC23FB Atwood HW heater situation:
Works on propane; stopped working on recent trip when using electric from pedestal.
With 120VAC on; confirmed voltage at breaker - not tripped;GFI not tripped.
With 120VAC off; 12VDC on and bathroom switch for electric heat on (red flicker then off like normal):
1. Checked electrical heating element - about 11 ohms
2. Checked continuity on ECO and T-Stat with - good - thermostats closed
3. Checked DC voltage to heating element relay - good about 12VDC.
4. Checked power to heating element relay continuity when energized: switch opens and closes when energized
5. Pulled apart 120VAC tape/wire nuts at relay and redid...still suspect?
6. Need to check wire connection at breaker for hot and/or neutral...loose?
Need to get to put 120VAC back on - to further test....any further suggestions on what I might be missing?
jftompkins is offline   Reply With Quote
Old 06-27-2020, 09:03 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you post the model number of heater itself?
Sounds like you have a meter. Have you checked for 120VAC on heating element terminals with switch on for electric heating?
GCinSC2 is offline   Reply With Quote
Old 06-27-2020, 09:37 AM   #3
JFTKSU78
jftompkins's Avatar
Olathe , Kansas
Thanks....That will be my next step when I get plugged back in to 120VAC.... I am guessing it’s either going to be at the breaker or the wire nuts?
How does a Atwood XT water heater make more hot water? Dremel Water Heaters, Filters & Pumps 9 10-27-2018 12:24 AM
Atwood Water Heater Troubleshooting tracker Water Heaters, Filters & Pumps 8 10-04-2018 04:03 PM
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Need help troubleshooting elec / gas water heater polarlyse LP Gas, Piping, Tanks & Regulators 0 08-26-2012 03:04 PM
Questions on Atwood water heater- troubleshooting wierdwiam Water Heaters, Filters & Pumps 0 09-20-2009 01:34 PM
