Old 04-13-2024, 05:14 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
arc snuffer for the water pump
i saw some people stating the the water switch on the water pump wears out over time due to arcing
its easy to prevent, just make a simple arc snuffer
simply add a 0.1 uf capacitor in series with a 100 ohm resister
place this is parallel to the switch on the pump
i potted mine with epoxy to keep it safe and dry
easy to make, simple to install
Name:	blocks arcing.jpg
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
My ribs donít make a complete arc? wagvan Ribs, Skins & Rivets 9 05-30-2021 06:11 AM
Dish Moving to Eastern Arc Satellites jcanavera Computers, Internet & Satellite 1 03-05-2014 11:28 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
