Accessing water pump on a 94 Excella
I'm trying to access my water pump via the false bottom in the CS wardrope. My setup is as follows: While facing in, there is a 90 degree corner-edge trim that runs along the left bottom side. There is another pieces that runs along the back wall and is miter with the other. The false bottom floor runs under both pieces of trim. There are also 4 screws, 1 in the back and 3 up front.
The only way to remove the false floor is to remove the corner-edge trim, but when I was trying to pry/remove the corner-edge pieces, they felt as if they were fasten and I would damage them if I continued. note: there are 2 wardrope doors and there is a vertical piece of wood in the center opening, which the doors close to.
If I need to be more aggressive in removing the trim, please share. I hope someone out there has a simular setup and will be able to walk me through it.
Many Thanks, John
