Old 03-27-2024, 03:35 PM   #1
scottsdale , Arizona
Wiring for tanks
Does anyone know how the wires attach to the waste tanks? I put on new tanks the old ones are long gone. So I have a bunch of loose wires that I’m sure if I hook up properly will help me to not over fill my black and gray tanks. Tanks a lot
By the way it’s a 1974 sovereign 31’ ft
augstwest is offline   Reply With Quote
Old 04-16-2024, 06:50 AM   #2
2006 25' Safari SS SE
New bern , North Carolina
Probably depends on the type sensor. If your tank has 4 wire/probes then the low one kinda by its self is negative. The other three located top, middle and bottom are positive. A water connection is made by the water from negative to positive depending on the water level.
Dan Jam is offline   Reply With Quote
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
Replacing water tanks, holding tanks & battery? Nelsons 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
