Old 09-25-2019, 06:16 AM   #1
1977 31' Sovereign
Dorr , Michigan
Where can I get replacement tanks
I am in the process of the teardown of my 1977 Sovereign 31' center bath and will hopefully be cutting the floor out (shell off will happen in the spring since i live in michigan and snow is coming) Part of my plan is to cut away some of the floor before winter to hopefully evaluate the condition of my fresh, grey, and blank tanks. Looking ahead I am trying to find sources to get replacement tanks for each of the tanks in the case that the original cannot be reused in my renovation.
Current plan is to keep the bathroom in a similar layout so i dont believe a custom inlets are necessary but not completely off the table either
Thanks for the help/
crazycuda is offline   Reply With Quote
Old 09-25-2019, 08:18 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Vintage Trailer Supply has some, and people have also used Inca Plastics replacement tanks. We got our fresh water tank from Inland RV.
Kay
Old 09-25-2019, 08:18 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The water tank is still probably available through Airstream dealers, or the online sources like outofdoorsmart.com or inlandrv.com.
If you want exact replacements for the waste tanks, they wre probably originally made by INCA plastics. I was able to get an exact replacement for my black tank from my '73 at a reasonable price from them. If an exact replacement isn't that important, but you still want the tank to fit inside frame rails, VintageTrailerSupply.com has some that are designed to do just that.
good luck!
Old 09-25-2019, 10:32 AM   #4
1977 31' Sovereign
Dorr , Michigan
good luck!
vintage trailer supply has tanks up to 1975 so my 1977 is not listed on any with them. I guess i will reach out to INCA if i need a tank
Old 09-25-2019, 10:55 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
How crazy do you want to get? Indeed this *is* the point to ask that question. No tanks have been bought and the layout is a "clean slate". Are the stock tanks big enough? Do you need / want larger? If you pull the floor now and take some measurements you have at least a month or two ( or six ) to do research.
Old 09-25-2019, 11:02 AM   #6
1977 31' Sovereign
Dorr , Michigan
Hi
That is some sound advice to get the floor cut out so and assessment can be made and over the winter we can go heavy into planning/decision making phase prior to nice working weather in the spring
Old 03-03-2020, 11:23 AM   #7
1977 31' Sovereign
Dorr , Michigan
good luck!
when i look up INCA plastics on google I am getting a website i find where is says to click here for the catalog but get sent to a server test page.
Old 04-21-2020, 07:11 PM   #8
1977 31' Sovereign
Dorr , Michigan
does anyone have contact info for INCA plastics? I emailed them months ago and got no response
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
can hear gas sometimes, and can smell from tanks KCG LP Gas, Piping, Tanks & Regulators 13 10-02-2017 07:43 AM
The Can Can Can travelfables Member Introductions 3 02-01-2014 01:56 PM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
