03-07-2023, 02:17 PM
1991 25' Excella
Central
, Arkansas
What a mess. Black tank cut with a skill saw.
That's right. We cut about 12" across the top of the black tank with a skill saw. I need a fix that hopefully doesn't require a new black tank. What would be a good fix? I think the tank is the ABS material. It's fairly thick and gray.
03-07-2023, 02:27 PM
North AL
, Alabama
I repaired a fairly large hole in a fresh water tank that I accidentally drilled through using G/Flex. Held up great for 2 years before I sold the trailer.
https://www.amazon.com/655-8-Pre-Thi.../dp/B00LWKFZJ8
It's fairly thick and can span gaps pretty well.
03-07-2023, 02:48 PM
2002 30' Classic S/O
Fleming Island
Get a strip of 1/8" ABS (saw blade width) and wedge it into the cut with ABS solvent cement. Test the tank first with some ABS cement to see if it softens. It might be High Density Polyethylene (HDPE). There may be a solvent cement for that, as well.
03-07-2023, 04:01 PM
North AL
, Alabama
Here's a video of someone patching a badly damaged black tank using G/flex and fiberglass. Pretty solid repair.
03-08-2023, 09:53 AM
GTL48
2018 33' Classic
Greeneville
, Tennessee
black tank repair
Consider Flex Seal.
03-08-2023, 10:04 AM
2019 25' Flying Cloud
Greeneville
, Tennessee
I recently heard of a "plastic welder", never seen one but see if Mr. Google knows about it.
Happy Camping
03-08-2023, 10:11 AM
diesel maniac
Airstream - Other
Tucson
, AZ
If it's only a slot in the top and it didn't affect the soundness of the structure I would choose one of the dozens of plastic tank repair kits available: https://www.amazon.com/plastic-fuel-...ank+repair+kit and after that dries I would apply a 2" strip of Eternabond tape and move on with the remodel.
Brian
03-08-2023, 12:38 PM
1964 30' Sovereign
Ione
, CA
All good advice in this thread. But am curious - - why did you stop after cutting through your black sewage tank? Seems like you could have continued (like I tend to) and rip through electrical wiring conduits too...
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
03-12-2023, 09:46 AM
1985 31' Sovereign
Lovettsville
, Virginia
If the tank is HDPE, you can get a plastic welder at harbor freight. They are very inexpensive and the material is easy and safe to work with, not to mention you can source your own from cleaned milk jugs if needed. For that size of repair, that might be the easiest and best. If it isn’t HDPE, that may not work.
03-12-2023, 10:55 AM
1957 22' Custom
San Diego
The advantage of an ABS tank, when you need to plug up leaks, is that ABS dissolves in acetone, but reverts to original hardness after the acetone evaporates. That means you can chemically weld ABS to plug up leaks.
Step 1: verify that the tank is really ABS by rubbing the damaged area with a paper towel that you've wet with acetone. If it's really ABS, the surface will quickly begin to dissolve and rub off onto the wet paper towel, and you can go to the next steps.
Step 2: get a short length of black ABS pipe, any diameter (sold at HD or Lowes) and saw it into small bits, say 1/2 inch or smaller.
Step 3: find an old wide mouth glass jar about a quart in size, put the ABS bits into the jar, add acetone to cover them, loosely screw on the jar top, and set the jar aside overnight.
Step 4: you will now have a thick ABS slurry. Stir it with an old stick or twig to confirm the ABS bits are all fully dissolved. Add more ABS bits and wait another day if the slurry is too thin. Add more acetone and stir if the slurry is too thick.
Step 5: use a small cheap paintbrush to liberally paint the ABS slurry over and around the opening to be sealed. You can apply several coats to build your repair to the same approximate thickness as the tank wall. The repair won't be pretty, and maybe not the same color as your tank, but it won't de-bond or separate because it's now part of your tank.
03-12-2023, 03:13 PM
2021 22' Bambi
Chelsea
, Michigan
The plastic used can be heated and "melted" back together. The melt temperature is ~400F. The trick is "sneak" up on the melting temperature or material will decompose. As you heat the surface with an iron you'll see the material start to flow.
03-12-2023, 04:54 PM
Boise
, ID
High class answers here. Wish I could [emoji106] them.
Of course my mind went to duct tape and flex seal.
03-12-2023, 05:43 PM
1966 17' Caravel
2018 23' Flying Cloud
Colleyville
1957 custom is correct. ABS plastic mixed with acetone or mek makes a glue once dries will work great. Automotive a/c cases are assembled this way.
03-12-2023, 09:23 PM
1988 34.5' Airstream 345
Clarkston
, MI
I used a 25 dollar plastic weld kit from Amazon to fix cracks in my tank. Be sure to use the stainless mesh to strengthen the weld. Works great.
03-12-2023, 10:24 PM
2013 23' FB International
aldinga beach
, south australia
id would use sikaflex marine 227?
it will never fail..like ever
03-13-2023, 11:42 AM
2014 27' Flying Cloud
Rancho Cordova
My first thought was it starts with an S and ends with Happens.
03-14-2023, 05:24 AM
2017 25' Flying Cloud
Traverse City
, Michigan
I used Marine Expoxy 5200 by 3M to reset the vent pipe to the black tank in our vintage A/S. it has been more than 5 years and thousands of miles. Still going strong. Good Luck.
03-14-2023, 05:33 AM
2022 20' Caravel
Southeastern
, Pennsylvania
JB Weld works well on ABS - but not on HDPE. Not sure what your tank is made of.
