Old 06-30-2020, 07:06 PM   #1
1984 31' Excella
Montara , CA
Waste outlet size on '84 Excella 31'
Our waste outlet on our '84 Excella 31 is 3-3/4" OD. We have a twist coupling fitting elbow that fits this waste outlet. The old sewer hose developed a leak so we bought a new Thetford Titan hose complete with fittings. The Thetford twist coupling is 3-1/2" ID so it's too small & won't fit on the outlet. We've searched far & wide and can't find a hose kit that will fit. So we cannibalized the hose kit and cut off the outlets but can't fit the hose on the twist coupling either. We can't find a hose that works either. Does anyone know who sells this bigger diameter sewer hose coupling & hose? Guess I can cut off the trailer coupling and glue on a new 3-1/2" ABS fitting but figured I would check here before modifying.
coastsider is offline   Reply With Quote
Old 06-30-2020, 08:22 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Sounds like you have a Thetford brand hose that fits a Valterra bayonet.
CRH is offline   Reply With Quote
Old 06-30-2020, 11:50 PM   #3
1984 31' Excella
Montara , CA
Well nothing "fits" so would you mind being a little more clear with a solution here?
Old 07-01-2020, 03:21 AM   #4
heslinhotel's Avatar
1989 29' Excella
1999 25' Safari
Youngsville , North Carolina
Sewer Hose
The connection you have is a Thetford. They do make an adapter to allow you to use Valtera (Black) hose on a thetford fitting. Most campers today use Valtera fittings, much less $$$ than the Thetford, and available everywhere.
I would suggest cutting off White Thetford fitting and install a Valtera fitting.
Steve
heslinhotel is offline   Reply With Quote
Old 07-01-2020, 07:31 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Yes, it is confusing. Older Airstreams have what is called Tetford fittings. Newer Airstreams and almost every other brand trailer have what is called Valterra fittings. Now for the confusing part: Tetford now makes hoses with Valterra fittings on them. That is what everybody uses and sells. You can order (but probably will not find in a store) a coupler that lets you convert the Tetford on your trailer to a Valterra. Stick it on with silicone caulk. Or, you can cut the end of the pipe off and glue on a Valterra adaptor as has been suggested. Outdoors mart Airstream sells the adaptor online. Amazon probably does too.
Old 07-01-2020, 08:11 AM   #6
Mollysdad's Avatar
While you're thinking about it, why not use the adaptor?
https://www.amazon.com/Valterra-T05-...3612696&sr=8-2
Name:	AIRMKT-eCom-PN-18415W-Thetford-to-Valterra-Universal-Adapter-42606-WEB-680x680.jpg
Old 07-01-2020, 09:31 AM   #7
1964 30' Sovereign
Ione , CA
Same problem with new tanks we had installed in our 1964 Sovereign 30'. We also found the https://www.amazon.com/Valterra-T05-...3612696&sr=8-2 adaptor. Works fine.
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 07-01-2020, 03:10 PM   #8
sammydgreek's Avatar
1991 25' Excella
belmont , North Carolina
I agree with Bill and imho the adapter isn’t worth it. Do it right - hacksaw the coupler off the old 3” waste line and glue a new on a Valtera. Less than a $5 fix.
sammydgreek is offline   Reply With Quote
Old 07-01-2020, 08:10 PM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
I have one of those adapters. Never used it. I don't believe it is either very secure nor leak proof.
Old 07-02-2020, 07:00 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The ears on the adaptor tend to break off.
Remove the old Thetford fitting and install a new Valterra fitting.
Old 07-08-2020, 10:40 AM   #11
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
I use the adapter. I put it on and leaver it on. Have had no problems and can use the much cheaper valtera stuff.
Gkiesel is offline   Reply With Quote
West Boondocking Waste Water and Food Waste Disposal Ray Eklund Boondocking 2 10-18-2015 02:38 PM
trouble hooking up waste water outlet to sewer hose Molly1973 Waste Systems, Tanks & Totes 9 05-21-2012 06:38 AM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
Is there a standard size...for the waste outlet? skip Waste Systems, Tanks & Totes 7 04-18-2004 09:05 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
